Question about Water Heaters
Lincat water heater - fault displayed on screen not heating properly
LINCAT E3BF WATER HEATER
If the pipe itself is protruding more than usual, it sounds as if the tank has corroded around the outlet pipe. If you just mean the pipe coming out of the bottom, you must find the source of the moisture.
It could be a leak on the top or above the tank, or it could be condensation. If it is a leak, it will get worse, and you will know for sure shortly.
Jan 28, 2016 | Water Water Heaters
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
AO SMITH VOLTEX ERROR CODE ELEMENT ON HEAT PUMP FAULT ON SCREEN
Copy following link
http://waterheatertimer.org/pdf/AO-Smith-heat-pump-service-manual-321547.pdf
Contact AO Smith for qualified technician in area.
Don't buy expensive water heaters.
Gene
h
Nov 09, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
Lincat EB3 water heater
The only thing that comes to mind is that you are on a well. Items like water heaters, heat pumps, sinks, etc are susceptible to mineral clogs. Usually this is solved by cleaning a screen on the inlet or outlet of a device such as a shower head. Thus resulting in more flow and pressure.
I hope this helps.
Oct 21, 2013 | Water Heaters
It often flashes ea or af and doesnt want to light
Before calling service technician, open following links for troubleshoot resources including common error codes, Bosch contact information, link to service manuals, and possible product manual
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Call Bosch 800-642-3111
Multiple error codes can mean PC board failure.
AF might be A9, but not sure.
EA is 'no flame ionization detected with water flow'
  1. Verify that all manual gas shut off valves are open.
  2. Check gas type.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Check three wire connections to ignition group on the lower front of the heat exchanger are secure.
  5. Check gas pressure.
  6. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod.
  7. Check that the minimum power fan speed has been adjusted to the proper value.
  8. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Aug 11, 2011 | Bosch AquaStar 2400ES-NG
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
No hot water but heating ok..no fault displayed ???
problem with tempering valve or if old,coil may be plugged
Jul 15, 2009 | Water Heaters
Water Heaters Logo
156 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
