Question about Garmin Nuvi 610 GPS Receiver
Keeps shutting down - even when I charge via computer. Within a few minutes the device shuts down. Same using car charger? Can you help?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Honestly you need to contact Garmin you definitely have a internal problem. It sound like have a component breaking down internally. Garmin will charge you to look at it if you are out of warranty with them, it might be worth it to have them tell you what component is breaking down. Their website is www.Garmin.com I would suggest you contact their tech department. Its not something that can be fixed with out the correct diagnostic equipment to pinpoint your problem. They have diagnostic software Im sure that will tell you what is wrong internally with your GPS. I have dealt with them in the past too and they are easy to work with and very helpful.
I hope this helps you out, if so leave me some feedback.
Posted on Apr 03, 2011
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Tomtom
My 2 year old TomTom gps Via 280 will suddenly not turn on
Jan 16, 2014 | Tomtom GPS
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
Jan 06, 2011 | HP Pavilion dv6000z Notebook
MESSAGE STATES THAT BATTERY IS LOW, AND KEEPS SHUTTING OFF. BATTERY SHOWN ON SCREEN AS DEAD.
plug it in to your computer via the usb cable for a few hours, the car and home chargers are not recommended for the initial charge as there only a trickle charge...if it still hasn't charged up using the usb cable, there is probably a problem with the usb port(charging port)
let me know how you make out after charging it via the usb cable that was supplied with the unit.
bill
Aug 20, 2010 | Tomtom ONE GPS Receiver
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
I have a go720 and it shuts off every 20 minuts it gives a warning first and if you see it you can cancle the shutdown. any sugestions on how to stop this.
If your device is on a USB DOCK and Computer it will shut down within 20minutes so it will give your tomtom optimal charge while on computer.
If your device is doing the same but on the USB car charger, there is a problem with the USB cable, its recognizing it as connection to a computer.
Best thing to do is try another car charger and see if that works.
Also make sure you don't use the home dock in the car.
Thanks
Pabz
Sep 24, 2009 | Tomtom GO 720 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Garmin Nuvi 610 GPS Receiver Logo
275 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
