Question about ASUS W7J Notebook
When i open my laptop, then boot, it goes to this windows 98 startup menu which has following options: reboot to windows xp, recover windows xp w/ full hd, recover xp w/ 2 partitions, and recover xp w/ 1 partition. i tried all the options but then it just hung up at the middle of the operation. actually, 2 days ago, my friend accidentally downloaded a windows 98 registry or something like that and installed it somewhere in my laptop. is there any way i can recover, least my files?
  • 41 Answers
First, recover your files. You will need to use something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Posted on Oct 28, 2012
  • 196 Answers
You need a registry cleaner,,,,,CLICK HERE
then apply TO XP Registry ..CLICK HERE
do vote if it helps
Posted on Apr 03, 2011
    Scholar:
  • 34 Answers
Reinstall the system and it will be OK.Then use a data recovery program to get your files back.
It is easy to recover the files.
Download this program called Tenorshare Data Recovery and run it.
This program is equipped with four critical modules:"delete recovery", "format recovery", "partition recovery" and "raw recovery". It may help with your case with "partition recovery".
You can get the program here:
http://www.any-data-recovery.com/
Posted on Apr 08, 2011
  • ASUS Master
  • 32,281 Answers
You need t install Windows XP to get your computer operational again.
To recover your data, remove your hard disk and connect it to an USB hard drive adapter then connect it to a working computer's USB port. This computer will see this as an external storage device, you can the open the various folders and files to back up your data files.
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Windows xp starts twice and on second boot wont load user settings
Does it just sit at a blue screen? Is there only one user profile on this system? It could be a bad user profile in which case you can try logging on as administrator (if that isn't the user account issue). Try taking it into safe mode or last good known boot and see how far you get. If you recently installed something software or hardware then it could be related to the installation.
Apr 29, 2009 | HP Compaq Presario V2000 Notebook
Dell inspiron 8100 notebook
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Jan 20, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Acer aspire t135 rebooting problem at startup constantly
I am assuming that it starts up, goes to the windows splash screen, the reboots and starts the whole process again?
Try to boot into safe mode: When you see the first screen, hit the F8 Key repeatedly, which should bring up a menu of boot options. Choose the safe mode option, and hit enter. If it boots into safe mode, I would start by running a checkdisk on the hard drive. Here's how:
Hit the Windows key and the letter R, in the prompt that comes up type in cmd and hit enter.
This should bring up the console. type in chkdsk /r/f in the prompt. It should say the drive is locked, and ask if you want to run on the next startup. Type y and enter. Then reboot. The checkdisk should run, and may be able to recover any bad sectors it finds. If it finds lots of problems, a more thorough diagnostic should probably be done, as the hard drive may be failing.
Jan 01, 2009 | Acer Aspire T135 PC Desktop
Laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Nov 19, 2008 | Compaq Presario Notebook
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
ASUS W7J Notebook Logo
129 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
