Question about Xerox 212 Laser Printer
Bonjour mon xerox 214 affiche le message u5 - Xerox 212 Laser Printer
3 Suggested Answers
  • 2072 Answers
SOURCE: Xerox Copier 214
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fiser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
Posted on Jan 29, 2008
  • 239 Answers
SOURCE: xerox 214 copier - U 4 code....what does it mean?
A U-4 code mean the machine did not reach to temperature.
On this machine check to see if the side door is completely closed.
This door also has some to close with a circuit board on the side.
Check to see on the side door if the small flat metal springs are aligned and not bent, with the power cord disconnected. If these metal springs are out of place a short can occur. Be very careful in this area. If you are not sure what you are doing do not try to service this area of the machine.
One other thing, if the machine has been stored in a very cold place, brining the machine to a room temperature will take about 2 hours for the machine's circuit boards just to warm up.
Usually on this problem, it may be a combination of problems. It means a new fuser assembly, or main circuit board. Not easy to get to, it is in the middle of the machine. Everything has to be taken apart without breaking other components.
Be very extra careful if you are doing this work yourself. This is why you should place a service call for a Xerox service rep to do the repair.
Posted on Oct 17, 2009
Mon tapis roulant sportcraft tx390 ,a commencer a sentir le brule 3 jour apret que jais du ajuste mon tapis car il avais tendense a bouge sur la droite et frote donc jais fait un ajustement et cest...
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Apr 12, 2012 | Cars & Trucks
BONJOUR JE POSSEDE UNE IMPRIMANTE LASER COULEUR SAMSUNG ELLE NE FONCTIONNE PLUS ET AFFICHE UN MESSAGE D ERREUR SYSTEM ERROR CYCLE POWER QUE PUIS JE FAIRE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Aug 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Lorsque j'essaye d'installer le driver de mon webcam sur aspire 5742 un message s'affiche unreconized camera et lorsque j'essaye d'ouvrir acer crystal webcam il y a un message...
salut !
je pense que le pilote ne fonctionne pas correctement
voila un site qui vous permet d'analyser votre ordinateur puis d'afficher automatiquement les diff?rents drivers compatibles.
juste lance la d?tection et suivi les instruction
http://www.touslesdrivers.com/index.php?v_page=29
merci de choisir fixya
May 22, 2011 | Acer Aspire 5742Z-4200 Notebook
J'ai installé un routeur trendnet
Bonjour You are having a problem setting up and installing your router? Go by the directions that came with your router to set it up.
Jun 27, 2017 | Computers & Internet
BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Mar 03, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Probl?me H 4
KEY IN THE FOLOWING KEYS
PROGRAM.ENTERPT,CLEAR. INERPT...this will give you access to the service mode
than ENTER #14 THAT PRESS THE START KEY
GOOD LUCCK
Dec 14, 2008 | Sharp AR-5316 Advanced Digital Imager...
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Carte son
Bonjour,
Je ne parle pas tres bien francais alors je m'excuse pour les fautes grammaire. Quelles drivers vous avez besoin? Driver pour connection d'internet? Ou le drivers de music? Etc.
Apr 13, 2008 | Computers & Internet
Ribver ipod iriver plus h10
http://www.fixya.com/support/t204392-system_files_missing
Nov 16, 2007 | iRiver H10 MP3 Player
Xerox 212 Laser Printer Logo
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
