There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
