Question about Dryers
It makes all the right noises but the drum doesn't turn any more, and it does not dry clothes.
  • Jimmydee7465 Aug 05, 2008
    I don't know. Tried to get to the belt but couldn't figure out how to get to it.
  • 770 Answers
Are you sure the belt is not broken have you checked??
Posted on Aug 05, 2008
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Maytag neptune washing mach.mod. mhw2000aww is making a very loud spinning noise and leaking from the rear of the tub.
  • sounds like the drum bearing is bad, which also damaged the drum seal.
  • the drum bearing and seal is on the back of the washer under the large pulley.
  • the brown splatter is an indication of the leak.
Jul 04, 2008 | Washing Machines
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 | Dryers
Dryers Logo
Top Dryers Experts
