The tv bravia kdl32u3000 is on stand by mode flashing 4 times. what does it mean?
jdbouncer
  • 72 Answers
SOURCE: my phillips flat tv won't turn on?
Error 4 indicates a communcation error between SSB and logic board. Which your problem is goning to be the BGA IC.
It will be cheaper to just get a new TV. But if u want to try and order one look online at parts.com.
Posted on May 03, 2008
mistersony
  • 320 Answers
SOURCE: sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
Posted on Nov 08, 2008
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
  • 197 Answers
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Posted on Jul 02, 2009
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Stand by light blinks in a 4-blink sequence after the tv works for 30 to 60 minutes
Hi saqa.
Welcome to FixYa.
My name is John, and I will be assisting you with your issue.
The four (4) blinks mean that you have no vertical Deflection, and
it goes into stand-by (safety mode) for protection. If you are not in
fear of high voltage because it can kill you! You can do this job yourself.
Let me know and I will post it here and the tools needed. Thanks for choosing FixYa.
Happy Holidays..........John
Dec 26, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The power light on my tv is flashing 4 times, what does this mean?
Dear sir or madam,
This probably means your tv is on Stand by or on sleep mode. Which probably won't let the tv work.
Sep 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV turns off automatically
turn off the sleep mode in menu/settings
Aug 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Stand By/Timer Flashing 4 Times
It means that there is a horizontal sweep or High voltage circuit falure. It is a high voltage circuit and only a trained tech should attempt to repair these sets. A TV set is not a place to be experimenting inside of.
Sep 26, 2006 | Sony KP-53V85 53" Rear Projection...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
