Question about Sport & Outdoor - Others
I have an 1986 viscount regency ultra light when towing with the nissan patrol it does'nt sway when i tow it with the land rover disco i'ts all over the road & thats with new tyres
  • thehutch Apr 03, 2011
    Hi richroth, i have tried all of the above but the problem still remains.
    I forgot to mention that i have air bag suspension on both vehicles.
    Regards thehutch.
  • thehutch Apr 04, 2011
    Hi dcramer531, thank you for all your suggestions & advice.
    Regards thehutch.
    President:
  • 1,654 Answers
The hitch height must match that of the Nissan apperantly land rover is either too high or low depending on how you have it set up. A trailer does not care what is towing it as long as it is as close to level as possible. Either that is the issue or the land rover has an alignment issue and is not tracking properly with the front and rear wheels. They should be in alignment as well. You might need to have the rover get a 4 wheel alignment to correct this issue. Wind around the vehichles also plays a part in the trailer tracking straight behind the tow vehichle. You might need a sway bar mounted on the Rover to the trailer if the wind is causing this. There really isn't much else to check exept load conditions. Is the trailer loaded the same when you pull it on either truck? The majority of the loades weight need to be as close to the center of the axles as possible in the trailer.
Posted on Apr 04, 2011
  • Dcramer531
    Dcramer531 Apr 05, 2011
    Hello, just saw the comment on the air bags, I assume you have checked and made sure the air pressure in the bags as well as the hitch height are the same on each vehichle. These need to be the same on the rover as the nissan since the nissan works well with your trailer.
    Top Expert:
  • Sport & Outd... Master
  • 9,472 Answers
The ability to handle and unstable trailer will depend on the inherent stability of the tow vehicle, which is yet another variable. A truck or van with a long wheelbase, a relatively short rear overhang and stiff springs often will at least partially make up for a trailer's lack of inherent stability, whereas if the trailer is towed by a softly sprung vehicle with a long overhang, the trailer's shortcomings will be more obvious.
Another important factor in tow vehicle/trailer stability is proper adjustment of a conventional load-distributing hitch. Proper adjustment means that the trailer is level and that the tow vehicle was level before hitching, it should remain at that angle after hitching.
The concept of a properly operating load-distributing hitch is that it should distribute hitch weight to all axles of the tow vehicle and the trailer. Here's how to make it happen:
1. Measure the tow vehicle at reference points on the front and rear bumpers with the vehicle loaded for travel, but prior to hitching.
2. Hitch the trailer and adjust spring-bar tension, so weight appears to have been added to the front as well as the rear of the tow vehicle.
3. Measure front and rear reference points again. If, for example, the rear of the vehicle has dropped one inch and the front has only dropped a quarter inch, add more tension to the spring bars, which will raise the rear and lower ther front. Continue adjustment until the measurements are approximately the same. If a discrepancy is unavoidable, the rear of the vehicle should drop slightly more than the front.
If the spring bars cannot be adjusted tightly enough to achieve similar or identical vehicle-height reduction, stiffer spring bars may be needed. The spring bars should be rated for at least the amount of hitch weight of the trailer, plus about 200 pounds if the tow vehicle is softly sprung.
If, after proper adjustment of tow-vehicle attitude is achieved, the trailer is not level, the ball mount should be raised or lowered. Bolt-together ball mounts permit ball-height adjustment. If the ball mount is welded to the shank, replace it with a ball mount that can be adjusted. (Such mounts are available at hitch shops.)
Posted on Apr 03, 2011
What is the towing capacity of a 1992 automatic Nissan patrol station wagon Y60 4.2 petrol?
Rated Towing Capacity†
Trailer with brakes (kg) manual/automatic 3200/2500
Trailer without brakes (kg) 750
Towball download (kg) See table
Gross front axle capacity (kg) 1500
Gross rear axle capacity (kg) 1800
http://m.nissan.com.au/~/media/Files/Brochures/Specifications/Y61_Patrol_Specification.ashx
Nov 30, 2016 | Nissan Cars & Trucks
I am trying to find out the towing capacity of a 2009 turbo diesel Nissan patrol. I have been told that being an auto reduces this.
best place to ask are towbar fitting shops
they have to certify that the modification and stamp the towing capacity
call any nissan service center and they will know
read it in your user manual
it has nothing to do with the transmission but a lot to do with whether the towed vehicle has electric brakes , over ride brakes or no brakes
Nov 25, 2016 | Nissan Cars & Trucks
Towing capacity of Nissan patrol ute tray top 4.2litre manual diesel
Make & Model G.C.M. Braked Trailer Toyota 70 Series 6830 kgs 3500 kgs Nissan Patrol (leaf springs) 6600 kgs 3200 kgs Nissan Patrol (coil springs) 6350 kgs 3200 kgs Beadell Tours 4WD VEHICLE TOWING COMPARISONS
Nov 23, 2016 | Nissan Cars & Trucks
Common problems with disco 2 year 2000. thanks v8
Good job I know what a 'disco' is. Mother worked for Land Rover :>)
Land Rover Discovery 2 Buyers Guide - Coventry West
www.coventrywest.com/d2-buyers-guide
  1. Cached
  2. Similar
Check out our Land Rover Disco 2 Buyers Guide for information about ... used Discovery II, it is important to familiarize yourself with the common problems these ...
Common Problems and Fixes - Discovery 2 - K Motors
www.kmotors.co.uk/vehicles/discovery-2/
  1. Cached
  2. Similar
The Discovery 2 is one of the best vehicles Land Rover ® have produced but they are beginning to show their ... Most Disco 2's have air suspension on the rear.
Land Rover Discovery Problems, Reliability, Recalls, Faults and ...
www.autoexpress.co.uk > Land Rover > Discovery
  1. Cached
  2. Similar
Mechanical reliability continues to be a problem for Disco owners, but seat comfort, ... Had 2 faults on delivery-both were badly fitted switches/sensors-bonnet ...
Known issues Disco 2 TD5 - Land Rover UK Forums
forum.landrovernet.com > ... > Land Rover Discovery
  1. Cached
  2. Similar
Aug 21, 2009 - 15 posts - ‎8 authors Anyone ever compiled a list of known issues with these vehicles, mine's a ... ...don't forget my own personal favourite (NOT) the cracked common fuel ... Bought it new in 2000 TD5 series II and to make a long story short I was ... Discovery V8 9 posts 29 Nov 2010 common disco td5 problems 9 posts 6 Nov 2007 More results from forum.landrovernet.com
Land Rover Discovery Review (Reviews) and Report, Land Rover ...
landroverhell.com/
  1. Cached
  2. Similar
I ran a series of Land Rovers from a 108 Safari through to a 90 TDi. ..... The list of common Disco 2 faults is always the same, so i'm just getting them done.
NIGHTMARE TD5, Land Rover Discovery Revies and Report, Land ...
landroverhell.com/article/3125/
  1. Cached
  2. Similar
Bought a disco td5 in november 2011, within the 2 months i owned it it had, new .... I would like to point out that these faults are just your run of the mill every day ...
Land Rover Discovery Repair: Problems, Cost and Maintenance
repairpal.com > Cars > Land Rover
  1. Cached
  2. Similar
Learn about common Land Rover Discovery problems, recalls and typical ... 2001 Land Rover Discovery. 2. answers. my A/c blower motor isn't working!
?LIST? Most common issues with disco II and what parts would you ...
landroverforums.com > ... > Vehicle Line Up > Discovery II
  1. Cached
  2. Similar
Jan 12, 2012 - OK I have a 2000 disco now just did the cld linkage from disco I on it, did all the fluids, drive shaft and now the complete gasket kit and ... Thinking about buying a discovery II - Land Rover Forums - Land ... 18 Aug 2012 About to buy 2001 Land Rover Discovery Series II LE - Land ... 8 Mar 2010 What to look for when buying a Land Rover Discovery - Land ... 17 Apr 2009 More results from landroverforums.com
Discovery II - A Let Down - Australian Land Rover Owners
www.aulro.com > ... > AULRO General Forums > General Chat
  1. Cached
  2. Similar
Apr 15, 2011 - 10 posts - ‎9 authors Here has been my Land Rover Discovery Series II experience so far. .... around the windscreen - apparently another common Disco problem!
Land Rover Discovery II: Problems and Recalls - AustralianCar.Reviews
australiancar.reviews/reviews.php#!content...Land%20Rover...Discovery%20II...
  1. Cached
Recalls, problems and faults for the Land Rover L318 Discovery II (1999-04). Includes problems and causes, from owners, repairers and technical service ...
Common problems with disco 2 year 2000 Google Search
Nov 11, 2016 | Cars & Trucks
If towing a 2tonne boat with a Nissan Patrol Ute can I also load the ute with any more weight?
what is the load capacity and towing together? look at the id plate on the door jam
Feb 11, 2015 | Nissan Cars & Trucks
Range rover problems
Did the tow company put a fuse in position 37 of the glovebox fusebox? This puts the transfer case into Transfer Neutral for towing. Refer to the Owner's Manual under Emergency Information ->Vehicle Recovery->Towing for Recovery
Jul 02, 2014 | 2005 Land Rover Range Rover
I have a 2003 range rover l322 4.4v8 i had to have i towed in after the warter pump failed it was towed in around 13 miles useing the proper operation of puting the transfer box in nutral as show in the...
well its a tow truck back to landrover service centre
sort out the battery charging problem and parasitc draw
out of the battery
and clear the fault codes
Mar 26, 2017 | 2004 Land Rover Range Rover
Disco gearbox problem
USE THIRD GEAR WHILE TOWING NOT OD. THE ADDED WEIGHT IS CONFUSING THE SYSTEM , ALSO CUNSULT YOUR OWNERS MANUAL UNDER TOWING FOR FURTHER RECOMENDATIONS
Oct 04, 2009 | 2001 Land Rover Discovery Series II
All stop lights not working just fitted towbar worked when first fitted
u have shorted out the brake lights, disconnect the tow bar and replace the fuse, the tow bar wiring is shorting out
Sep 04, 2009 | 2004 Land Rover FreeLander
Sport & Outdoor - Others Logo
98 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
