Question about HP Media Center m7250n (ED842AA) PC Desktop
HARD DRIVE INSTALLATION/ - HP Media Center m7250n (ED842AA) PC Desktop
  • HP Master
  • 32,281 Answers
For instructions on installing HARD DRIVE please click on this link :-
http://www.ehow.com/how_4530755_replace-existing-hard-drive.html
Posted on Apr 03, 2011
Maxtor 32049h2 20.4 GB setup disk for windows 2000
After installing the hard drive in the computer then boot up with the Windows 2000 installation CD. Proceed with installing Windows. delete the existing partition , create a new partition, then format the hard disk in NTFS file format, follow the instruction to complete the installation.
You will also need the product installation code to complete the installation and you will need to activate the Windows license by the Internet or by phone. You will also need to install the motherboard device drivers.
Mar 14, 2013 | Maxtor DiamondMax VL 40 (32049H2) 20.4 GB...
Tip
How to Install an Operating System on an External USB Hard Drive:
You may have an external hard drive you want to use for more than just document backup.
In this situation, you can install an operating system onto your external hard drive. By doing so, you will be able to run your external hard drive as a fully functional operating system.
If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup.
1) Plug your external Hard Drive into your Computer using the USB cable. Insert the installation disk for your Operating System into the CD/DVD Drive. Turn on or restart your Computer.
2) Boot from the installation disk. You may have to press a key once prompted to boot from the installation disk.
3) Accept the license terms and conditions. Read through these carefully if you wish to understand your legal rights as a user. If you disagree with these terms and conditions, you may want to purchase a different Operating System.
4) Choose your destination drive. Your external Hard Drive will likely be the E: or F: drive. By default, the C: will represent your main Hard Drive and the D: will usually represent your CD/DVD Drive.
5) Begin the installation. Your external Hard Drive will install the Operating System. You will now be able to run that Operating System off of your external hard drive.
Hope this helps.
on Sep 03, 2010 | Computers & Internet
I have compaq nx6310, i had issues with the os.once you touch a button it starts open other buttons and pages automatically. i tried restoring the system to earlier dates and the issue reduced. later on it...
Hi das4real! These are the things to consider.
  • Operating system disk - Try to test your Installation CD to other computer. If it doesn't work then you need to replace the disk
  • Optical Drive (CD/DVD Drive) - If Installation disk works then try to clean your Optical drive lens as it may be having a hard time reading the disk. Your Optical drive is working since you're able to format and able to start the installation. Cleaning the drive lens may do the trick.
  • Hard Drive - If Installation CD and Optical drive is clean. Then the last thing you need is to replace the Hard Drive. You Hard Drive might need replacement due to some bad sectors and the installation couldn't write anything on the drive that causes to freeze during installation.
I hope this helps you.
Mar 15, 2011 | Computers & Internet
Bought a used IBM ThinkCentre M52 8215-VAN S/N LK71288 for $5.00. Needed memory and hard drive. Installed memory. Don't have harness for hard drive. Not sure where to plug hard drive in. Has optical...
if you have any discs in the dvd remove them... it should boot to the hard drive when it doesn't find anything in the dvd. if you need to install an operating system put that disc in the dvd and boot from it. during the installation it will start to run off the hard drive. when you are done installing remove the installation disc.
Sep 30, 2010 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
I bought a seagate 500 But I don't know how to put pictures on it
Yes. Its possible.
  • Step 1: Analyze the system requirements of the Windows operating system. Windows XP requires 1.5 gigabytes of free hard drive space. Windows Vista requires 20 gigabytes (for the Home Basic edition) or 50 gigabytes (for all other editions). The system requirements for older, outdated versions of the Windows operating system, such as Windows Me and Windows 98, can be found on the official Microsoft Windows Web site (link in the Resources section).
  • Step 2 :Connect the external hard drive to the computer with which you plan to use the hard drive. Use the hard drive's original cables included by the drive's manufacturer. It does not matter what connectivity standard you use. Windows will automatically detect the external hard drive.
  • Step 3: Click the Start menu in the lower left-hand corner of the PC screen and select My Computer.
  • Step 4: Right-click the icon for the external hard drive. Click Format from the pop-up menu. Format the external hard drive in the NTSF format.
  • Step 5: Insert the original Windows installation disk into your computer's CD-ROM drive. Close the Installation Wizard when it appears on the screen.
  • Step 6: Return to the My Computer window from Step 3. Write down the drive letters assigned to the CD-ROM drive and the drive of your external hard drive. For the sake of this article, we will use the example of D:\\ being the external hard drive and E:\\ being the CD-ROM drive. These are typically the letters assigned to CD-ROM and external drives in the Windows operating system.
  • Step 7: Click the Start menu button and select Run.
  • Step 8: Type "E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot" (without quotation marks) and click OK. This launches the Windows installer file on the Windows installation disk in drive E:\\ and commands it to install on the D:\\ drive (your external hard drive). The Windows Installer Wizard screen will appear. (Change the Drive Letter as in your Machine)
  • Step 9: Select the Full Install option in the Windows Installer Wizard. You will then be guided through the Windows installation disk. Follow the on-screen prompts to complete the installation. Depending on the speed of your computer's processor, this may take several hours. Be prepared to enter important information, such as your Windows registration key to register your copy of the Windows operating system. Do not close the installation window until the installation process is complete.
Please rate the answer if you feel that this solution solved your issue.
Thanks for contacting Fixya!
Step 10 Shut down the computer and disconnect the external hard drive. You can now use the external hard drive to boot up another computer using the installed copy of the Windows operating system.
Jun 29, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Trying to partition internal hard drive, taking along time!
Windows 98 thru Vista will partition format the hard drive during installation. Starting with XP, it can handle partitions over 1GB (1000MB).
If it is a new drive, let windows do a "quick format" during installation.
Jan 09, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Erase a hard drive
IF you have the XP installation CD you can easily do that, Just set your BIOS to boot from the CDrom then put the XP CD on your CD drive then restart the computer , so your computer will automatically boot from the XP installation CD then on that process you will have an option to format the entire hard drive that you have using the XP CD installation, then just let the installation finish...
Oct 16, 2008 | Computers & Internet
Installation
unplug you hard disk, then switch on without your hard disk let your xpcd in your cd rom to run after reading your cd ''saying, no hard drive found'' switch off then plug it in your installation will proceed
Nov 27, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
No recognize
The drive will need to be extracted. The enclosure and/or drive has failed and is causing your computer to fail. Remove the drive carefully from the enclosure and test it in a good, known working stable enclosure...
www.drivesavers.com
keep me posted
Oct 29, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Hard drive
Yes, you can upgrade to 120 GB. Here is an installation guide: http://www.bixnet.com/hadringuh2.html Make sure you purchase a laptop hard drive; they are different than desktop hard drives. A 2.5" one will work. Don't buy it from the site with the installation guide, however. You can get them cheaper from Tigerdirect.com.
Jun 21, 2007 | Compaq ( 336992-001) (336992001) 80 GB...
HP Media Center m7250n (ED842AA) PC Desktop Logo
19 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
