Question about Samsung ML 1610 Laser Printer
I install ml1610 driver in win 7 and it not printing bottom of page for a4 paper in another computer when i share it
  • 14 Answers
SOURCE: Epson C900 print shifted down page -
hi chara
chara i have delayed to respond to your question because i wanted to simulate your situation. To say the least i have setup my machines to the dimensions you have mentioned but i still get good prints with obviously that final message that "incorrect paper size"
pass more details on 1. ms image version 2. printer settings (reset all to default) 3. ms image printer properties settings.
i have a feeling that this problem come from ms image end
Posted on Dec 20, 2007
SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
Unable to clear the store with this error showing!.. There were no jobs to clear.
Well, if you unplug the power and allow the unit to discharge,(maybe overnight), the error situation clears.
Posted on Mar 18, 2008
  • 39 Answers
SOURCE: Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
Posted on May 22, 2008
  • 35 Answers
SOURCE: jammed paper Samsum ML1610
Take down the front cover, pull the toner cartridge out and pull the paper to remove it. Check the plastic wheel that feeds the paper (use a flashlight). It has a rubber band that might be broken. Replace it if necessary.
Posted on Apr 29, 2009
SOURCE: Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Posted on Oct 15, 2009
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in system..select proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
Mar 30, 2012 | Office Equipment & Supplies
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
Hi, my Xerox phaser 6110 is installed on a Windows XP computer and i'm trying to share it with another Windows 7 computer on the same network. Unfortunately, the drivers i downloaded for windows 7 will...
follow this simple steps:
  1. Share you printer
  2. Go to your Win 7 PC
  3. Find your Win XP PC on network
  4. Click to see shared devices
  5. Right click on Xerox 6110 icon and then click "Conect"
Enjoy!
Mar 13, 2011 | Xerox Phaser 6110 Laser Printer
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
The network printer will print a test page but nothing else
whenever a printer is connected to a network it loads a driver for all the lower versions of operating systems so that if any computer from the network having a lower version gives a print command it can be spooled using that driver. On the other hand you have connected the printer to an OS of low version and printing through a higher version. Its just like connecting a printer to DOS comp and trying to print through Win 98. So now you know what you have to do. Just find your driver compatible for Win7 and connect it to win7 and you can give print through xp.
Apr 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have HP 2015dn printer. In Windows XP I can print duplex automatically. In Windows 7, when I installed the printer, it uses the default driver from Windows. When I tried to print duplex, it printed the...
No there isn't that's the biggest problem with Win 7. DRIVERS.. if they aren't expressly written for Win 7. Then it is all just one big headache. In saying that sometimes installing as Admin, & in XP SP2 Compatibility Mode, helps.
Feb 03, 2010 | HP LaserJet P2015 Printer
My ml 1610 printer says its not connected to my computer even though the cord is pluged into the usb port
Check the hardware and software settings first
1) Check the Hardware Connection -
a) Power connection to Printer
b) USB Connection from Printer to Computer
2) Checked the Drivers Software
a) XP/Vista = Open the device manager
Click Start - right click on My Computer
Click on Manage
Click on Device Manager
Click on (+) Ports COM & LPT and Check Printer is listed or not
or
Check for Printer Name (Samsung ML1610) is it listed under device manager
if YES - Check by printing the test Page
if NO - Install the Printer Drivers and then print the Test page
Jan 21, 2010 | Samsung ML 1610 Laser Printer
After I install the driver for my Canon MF3220 on my laptop with windows 7 x64 ,I cannot print.Help me please
Go to File.. Print.. then Properties. Where it says output size change it from Match paper to A4 (i.e so it matches output size). Seems to solve the problem although keeps defaulting back!
Jan 05, 2010 | Canon LaserBase MF3220 All-In-One Printer
ML-1610 Printer driver download
Do you have (software For Samsung ML1610)
Oct 21, 2008 | Samsung ML 1610 Laser Printer
Printer keeps saying change paper size
Go to Control Panel - Printers and on MF3310 right click and choose Default settings. I had to change page size from Letter to A4 and output size from Match page size to A4 as well. Finally, after 4 hours of investigations it worked.
Jan 30, 2007 | Canon MF3110 All-In-One Laser Printer
Samsung ML 1610 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
