Question about Acer Aspire 3680 Laptop
Linksys how can linksys assign a network address to my computer?
  • geckogarnett Aug 05, 2008
    i already have the net work address for lniksys wireless neywork ( i need to know now how to apply this address and where to apply it so that it can work properly.
  • Josh Barrett May 11, 2010
    Could you please be more specific? Are you asking how routers work?
Http:// is the web address to modify the settings on your router. You type that into your web browser (Internet Explorer, Firefox).
Posted on Aug 05, 2008
How can I make settings to support DHCP IP assignments and also recognize my manual IP's assigned to the LAN connected devices?
The easiest way I can think of is to shrink the DHCP address pool.
To do that, at least on the model of Actiontec router I have, click on "Network (Home/Office)" the go to the "IP Address Distribution" section of the screen. "DHCP Server" should already be selected, and under that, you'll find "Start IP addresses" and "End IP addresses." Usually, the start will be and the end will be What I usually do is change the start address to That leaves over 50 addresses for normal wireless connections, and I'll general assign IP addresses from the rest of the range as follows: to routers, APs, etc. to printers to for other static devices. (I often find that Blu-Ray players, cable boxes, etc. behave better if they have a static address.)
But really, on home network, I doubt you'll have more than 15 devices that need static addresses, so you could set the DHCP start address as low as if you wanted to.
Sep 17, 2015 | Linksys Computers & Internet
Why wont my computer obtain its ip address
How many computers do you have in the network?
How many are not able to access the Internet or IP address?
If only one computer is not able to access the Internet then you can try assigning a static IP address on the computer and see if you can access the Internet.
If all the computers are not able to get IP address from the router then I think you should try to reset and upgrade the firmware on the router.
See How to upgrade firmware on Linksys router.
Mar 11, 2012 | Cisco Linksys E1000 WirelessN Broadband...
How do i retrive my password
Log onto the router using the for Linksys in the address bar then look under the wireless settings in the router.
Look at the IP settings from a computer that is connected the the network to find the address of the router. The default gateway in the connection properties is the address of the router.
On the computer connected to the network,
Press down "Windows key" on your keyboard and Letter R
Type "cmd" with no quotes in the Run Dialog and
Hit enter,
Type "ipconfig /all" and hit enter in the command prompt.
This is if the IP address is dynamically assigned by the router.
Good luck to you
Jun 22, 2011 | Linksys Wireless-G Broadband Router
My wireless network connection shows excellent signla but my Laptop can not connect. It says the problem ouccured because the network did not assign a network address to the computer. How do I assign a...
There is much you can try ... the easy thing is to get Network Magic from Cisco ... free download and eval period. I liked it so much I have a paid pro version.
NM will take care of all these little troublesome network management tasks. Find it here:
I hope this helps you
thanks for using
please vote
Dec 05, 2009 | Linksys Wireless-G WRT54G Router
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Connecting new hp deskhjet printer to network
first of all take one computer and unplug the network cable and connect your router with that system through the cross cable and than configure it. To configure that linksys router type the default ip in the browser e.g. and enter the default userid admin and passwrod admin.
Dec 03, 2008 | Linksys Wireless-G WRT54GS Router...
Logged off
The LAN should not ever log off but either you are talking about the Internet, which can, microwave devices (ovens, wireless phones) that intermittently interfere or dynamic ip addressing cycles that assign you the from within Windows attention deficit disorder manager. You can assure static assignments of ip addresses for your LAN (write down the ip address and default gateway when you are logged on to see what they should be) or log on to your router (Start>Run> type for Linksys, user name linksys, password is admin and you can configure your LAN and WAN. Select DHCP for cable modems, PPPoE for DSL or STATIC for ensuring LAN ip address assignments. ~Steve
Oct 17, 2008 | Linksys WUSB100 Wireless Adapter
Static IP on machine, now can't access web sites
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address, try If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Acer Aspire 3680 Laptop Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
