Philips computer battery not charging: I have a Philips Freevents laptop and two batteries for it. Suddenly last week one of the batteries, which had been fine up until then, stopped charging. The icon says: "0% remaining (charging)." But it isn't charging. I've tried my spare battery; same problem. Since it seems unlikely they have both collapsed simultaneously, I can only assume it's a software problem. Any idea how to fix it?
danasaur
  • 77 Answers
SOURCE: fujitsu lifebook t4020 battery connnection/charge problem
So, "all three batteries" suddenly get this zero charge. That is VERY "incriminating". Almost 100% certain you have either a connector problem (most likely) or a power regulator circuit failure (less likely). Get a flashlight and magnifying glass, and look deep into the battery compartment at the connector. Almost certain there is some bent pin or other irregularity there. If so, be careful straightening it out. Disconnect PSU and still, be careful not to cross-connect two connectors. Even though PSU and battery are removed, there is still a small battery inside that keeps that circuit alive for clock and PRAM settings... don't want to short that circuit out. Work only on one pin/strip at a time. Hope this is the problem. Because if it is the regulator circuit -that is a motherboard matter. Major repair, usually not worth the cost. But I really think that scenario is unlikely, unless you caused some serious short recently. Let me know what you see inside.
Posted on Feb 11, 2008
StuartB
  • 807 Answers
SOURCE: EI Systems 3085 Laptop will not charge battery
Yuo should measure the voltages from the charger not the PC.
May be the charger is broken.
Posted on Mar 21, 2008
SOURCE: Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Posted on Jul 10, 2008
SOURCE: Philips Freevents X56 laptop won't switch on!
Take it back to the shop. The Sale Of Goods Act says that goods have to last for a "reasonable" time. It is not reasonable for a laptop to break after 18 months.
See http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
or search for "Sale Of Goods Act".
It is possible, however, that the power button is broken. Try getting some compressed air to blow out any gunk from underneath it. If the laptop supports it, remove the keyboard any make sure you don't have biscuit crumbs under the key.
Posted on Jul 31, 2008
SOURCE: PHILIPS FREEVENTS X60 LAPTOP
The X60 is actually the "Twinhead Stylebook 10D", under the brand of "Philips". Everything you need can be found here: "http://www.twinhead.com.tw/site2005/download.aspx "
I had exactly the same problem after a hard disc format, and I was searching for many hours for the solution. After I installed these drivers, ALL the devices are working perfectly!
Posted on Nov 15, 2009
Testimonial: "Very M Thanks. Borhan"
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
Philips freevents 11nb5800 laptop. suddenly clicks off when used with power cable. does not happen when in safe mode?
Then you should run your computer Anti-Virus to check for them. Also run your disk check in safe mode. Then defragment your laptop if it says it needs it. Hope this helps!?
Please rate solution - Thanks
May 17, 2010 | Computers & Internet
The jack power charge socket has snapped inside my laptop
you need to go to a computer service place like Best Buy. they are good with that stuff. i had that same problem. they fixed it for not a lot of money.
Nov 23, 2009 | Computers & Internet
MY PHILIPS FREEVENTS X52 LAPTOP HAS STOPPED CHARGING ANY IDEA HOW I CAN DECIDE IF IT IS/ BATTERY,CHARGER OR CONNECTION PROBLEM
try this. remove your battery and plug in the ac adapter. If it starts and operates normally then you know it's not the AC adapter.
if your lucky enough to know someone with the same AC, borrow it. plug it in and leave it for an hour or two with the battery installed. unplug the ac and try running it off battery . if it works- not the battery-
^_^
Sep 13, 2009 | Computers & Internet
Philips Freevents X50 charging problems
well my friend I hate to say this but the problem is in the motherboard, and the motherboard should be replaced.
Jun 27, 2009 | Computers & Internet
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Computer is not holding the charge of the battery
Most likely it is the laptop battery, The PC will suddenly lose charge, the battery needs replacing, in my experience laptop batterts last about year before they get to 50% to 10% holding charge otherwords need replacing.
Jun 13, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Could be anyone of a number of things related to internal batteries. Let it charge for a while (does the charging light come on on the laptop? - isn't clear if the green light is on the powersupply or the laptop itself) and trying again.
Jul 31, 2008 | Computers & Internet
Philips freeVents X50 Model f12dt
here is a link to a few pages full of the battery you need:
philips freevent x50 model f12dt battery
hope that helps
also call best buy they can surely assist you or special order one for you, they also have many references of other places you can go.
May 15, 2008 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
