I have a 6 month old Philco fridge-freezer model PHTL763FFZ. The drainage filter in the fridge part must be blocked because I get puddles in the bottom of the fridge, and my user's manual says the drainage filter can be removed and cleaned (no further instructions given) ... but there isn't anything there that I can remove, the drain hole is moulded as part of the fridge interior and there is no insert that I can see. Have they forgotten to put a filter in or am I being dim? ps the Philco helpline on the manual is no longer in use.
SOURCE: Smeg dishwasher EN50242
have a Smeg STX-45 dishwasher. After washing the utensils, machine is not able to drain the water. Can you please tell me what could be the problem. Is there any switch I need to press for the same or something else. I have used the machine for the first time.
Posted on May 18, 2008
  • 4 Answers
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Posted on Nov 17, 2008
SOURCE: Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Posted on Mar 06, 2009
  • 659 Answers
SOURCE: Drain Problems on American Standard A/C and Heat pump
You have a plastic condensate pan and you could have developed a crack in it. But most likely, there is still something that is clogging the drain. You may need to run a snake through it instead of using air. If you ran a snake through then it's probably a crack. Sometimes the crack can be at the outlet where something might have hit the pipe. Also, if the unit has a "draw through" coil, then there needs to be a p-trap installed on the unit to keep water from being drawn back into the unit while it is running. If it is a "blow through" coil and a p-trap is installed then remove it. The p-trap can restrict the flow of water leaving the unit and the least bit of debris can cause the unit to overflow. Draw through means the blower motor is pulling air over the coils and sits over top of the coil. Blow through means that the blower is pushing air into the coils and sits down below the coil. Hope this helps.
Posted on Mar 30, 2009
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
My french door freezer side water is dripping collect in the bottom of the freezer. its frozen solid and then melts and drips out the front of freezer onto the floor making a puddle of water
Your drainage hole is blocked.. empty the bottom half of the fridge and freezer .. you will see a V shaped moulding in the back panel INSIDE each compartment.. smack bag in the middle is a hole that allows the condensate to run away, but sometimes a pea or other obstruction clogs it, so the water cannot run away, but is held back.. where it refreezes, blocking the tube further, and causing the next cycle to run the water into the bottom of the appliance, where it refreezes.. but later thaws and floods.... I suggest you pull out the appliance so you can check the drainage tube(s) by eye.. use a chopstick, and if you can find a cheap shop selling 'bottle brushes' about the width of your little finger, push that up and down it a few times to properly clean it..
Apr 24, 2017 | Refrigerators
I have an artic king freezer model arco7mw and it has puddles of waterneath,why is that?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 02, 2015 | Refrigerators
Manage my life com sears
Jun 30, 2014 | Kenmore Refrigerators
Doewoo no frost fridge freezer is working fine except that we keep getting puddles of water under the freezer door. any ideas. had about 4 years now
probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Sep 02, 2012 | Daewoo Refrigerators
Daewoo side by side freezer leaking even though water turned off also icing up at bottom of freezer
Probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
Aug 30, 2012 | Daewoo Refrigerators
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
Top Freezer Whirlpool
THERE IS A PROBLEM WITH THE DRAINAGE. iTS BLOCKED. YOU NEED TO DEFROST THE FRIDGE PROPERLY FOR A DAY TO REMOVE THE ICE THEN APPLY PRESSURE (BLOW) IN THE PIPE SITUATED ON TOP OF THE COMPRESSOR.THIS WILL CLEAR THE BLOCKAGE. RESTART YOUR FRIDGE.
Aug 14, 2007 | Whirlpool ET8WTMXK Top Freezer...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
