Question about Garmin GPS
Power to unit but wont turn on - Garmin GPS
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
The larger Garmins require considerable power to charge and many non standard USB chargers will not supply enough power and respond with "use the cable supplied with the unit"
Kevin H
Posted on Apr 19, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I own a Garmin also, my suggestion is plug it in to your computer, leave your computer on so it can charge up overnight. If in the morning it wont power on my suggestion would be to contact Garmin you may have a bad battery or some other internal problem. Garmins web site is www.Garmin.com Contact there Tech department to see what they would charge you to check out your unit. It has to be cheaper than buying a new one.
I hope this helps you out if so leave me some feedback.
Posted on Apr 03, 2011
My thermostat says the heat is on and its set to auto but the furnace wont turn on we've reset circuit breakers turned the unit off and on checked the filter but it wont turn heat on.
Look for this. 24 volt transformer. Thermostat sends 24v to the unit in order to tell the unit to turn on. The transformer is probably bad or isnt getting power and the unit isn't getting the "turn on signal"
Get a test meter and touch the two screws. If it's not getting voltage, check the 120v wiring to it and make sure it's getting 120v. If it's getting 120v at the wiring but not 24v at the screws then the transformer is bad. Easy to change and common part. Home depot or Lowes for about $35
Oct 17, 2017 | Power Computers & Internet
Unit wont turn on.
try test the remote using cellphone camera.hold remote facing the camera lense as if u taking a photo. you should see wht appears to be a flashing light when pressing any key on the remote. should you see no flashing i would say the remote is faulty.
Oct 05, 2015 | Heating & Cooling
Power button keeps blinking dvd player wont turn on
the disc or mechanism may be jammed and the unit knows this, someone (most shops do this) needs to open the unit and safely cycle the disc out of the unit---many times with this done the unit will suddenly work again.
If not and it is not a expensive unit you have the disc back and time to go shopping as most of these are throw away units.
Sep 03, 2012 | Televison & Video
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
Xbox wont turn on its pluged in and getting power to the unite but wont turn on
What color is lit on the power unit? Is it red, yellow, or green? Are you using a wireless controller to turn it on or the actual button on the XBOX? If you're using the wireless, make sure it's plugged in to the unit and controller. If not, replace batteries in controller and see if that works. If still nothing make sure you have a good connection between the power unit and the XBOX.
Dec 06, 2009 | Microsoft Xbox 360 Console
Dvr unit wont power on
Processor has gone wayward with over a million transistors it is amazing electronics are as dependable as they are. Send in your unit for repair or replace it.
Nov 30, 2009 | Cars & Trucks
Their is power in the fuse and in the power line but unit wont start is their an internal fuse or am i missing something
Hello paul543,
First check all the fuses. The primary and any onboard fuses.
Then, in addition to the power wire, check the ground and make sure that there is +12V on the remote turn-on terminal when the head unit is turned on.
Hope this helps
May 01, 2009 | Car Audio & Video
Wont power up optoma movie time
it's probably not this: Try using the remote to turn it on. I cleaned out mine a while ago and the controls on the main unit stopped working. Only way to turn it on now (for me) is the remote.
Feb 12, 2008 | Optoma MovieTime DV10 Multimedia Projector
KDF-42WE655 Wont power up
you need to buy a bulb for the tv its about 179.00 on ebay
Nov 07, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
GPS Logo
165 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
