Question about JVC CH-X1500 12-Disc CD Changer
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm going wrong! I've a JVC head unit (JVC KD BT-22) I just bought a CD Changer cheaply off eBay (JVC CH-X550) This didn't come with a cable so I bought one off eBay. I've installed the head unit, run the cable through the car, fitted the CD changer in the boot but there doesn't seam to be any power - there's no lights on the unit and the button to eject the magazine doesn't work. I've looked at the settings on the head unit as I know sometimes you have to enable it for CD changer use. The only option i found was for Aux Input, which is set to CD changer. But when I scroll through the different inputs, the CD Changer isn't listed. Any ideas where I may be going wrong? Thanks in advance for any help you can give, Stu.
    Scholar:
  • 59 Answers
There should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Posted on Apr 03, 2011
Testimonial: "Thanks for the advise!"
  • moonklash Apr 03, 2011
    Thanks for the advise! Turns out the unit was okay and there wasn't anywhere for an earth cable to go, however it looks like the cable I was using to the connect to the head unit had a loose connection. The unit started working intermittently when not in place and stopping when in position - we figured the cables were getting pushed around and that was causing the problem.
    All sorted now, the unit started working intermittently and now it appears to be fine so I'm guessing it's just a dodgy cable :-)
Any idea where I can get my Yamaha CDC-610U 10 disc CD changer repaired in the Chicago area?
I here this guy is pretty good, http://www.anthonyses.com/ But he only does cash from what I'm told. Good Luck. Finding someone who can actually work with electronic at component level anymore is a real challenge, most guys are just parts changers.
Oct 22, 2016 | Yamaha Cars & Trucks
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
Troubleshoot cd changer problems
What are the problems exactly. You are being to generic.
Feb 18, 2015 | 1999 Audi A6
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Nov 06, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
CD NOT WORKING
IT MAY HELP IF YOU CAN REMOVE THE CD PLAYER AND THE POWER LEAD THEN REMOVE THE CD'S FROM IT (WITHOUT FORCING THEM) AND THEN RECONNECT THE POWER
Peugeot 406 (1999) LX + Clarion PU2293A 6-Disc Changer Problem
Bloody snap! I also have a 406. The button on the head unit is supossed to turn on player.My original unit wore out.I got a second hand unit which is also not recognized by the head unit. At the moment I dont know why,but Im not a man to give up easily and will give you the solution when I have it. I know it was working originally and it looks like the secondhand unit is faulty. thomaashamioton@email.com
Oct 04, 2007 | Clarion DC625 6-Disc CD Changer
Cd player
Regards
Mark
Blue ICE
Mar 11, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
JVC CH-X1500 12-Disc CD Changer Logo
397 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
