Question about Altec Lansing VS4121 2.1 Channel Powered Audio Stereo Speaker System (Retail) Computer Speakers
My altec lansing vs4121 speaker have to much bass with several mp3 files, waht ca i do
    Brigadier General:
  • 8,546 Answers
If it's only certain MP3 files you might want to identify WHY those files have too much bass. THAT would have happened when they were created. It's not a speaker's fault how the music sounds. Then there's your PC or whatever other device it passes through. Lots of opportunities for MALadjusted sound. GIGO.
Posted on Apr 03, 2011
Is there a way to use the Altec Lansing VS4121 Subwoofer as a stand alone?
Normally these low end systems components that depend on each other and cannot be interchangeable from other system. So if one of the components (sub woofer or right control satellite speaker) breaks or gets lost the whole system is unusable...
I was in the same situation. Got a sub woofer from VS4121 without original satellite speakers. I acquired satellite speakers from Altec Lansing 251 which used same connectors but the internal wiring was different and incompatible out of the box. Speakers are also glued together so it is impossible to open without damaging it. Not to mention there is no service documentation anywhere..
But if you like electronics you can try to make something based on the information bellow:
Altec Lansing VS4121 connector pinout
If you take the male connector (from right satellite speaker) and look at the pins and number them first row from left to right pins 1-3, second row pins 4-7, the bottom row pins 8-9 and the circle enclosure as 0
0 - Ground
1 - Speaker Right
2 - Treble (seems just like voltage control but may need to be confirmed: Min=0V; Max=voltage from Volume control Pin 9)
3 - Head Set Right
4 - Bass signal (not sure what the exact original design is as I have not opened the speaker) But seems like they use 50K potentiometer and some sort of RC low pass filter configuration. When potentiometer is set to Min it is shorted with ground. When set to Max it is taking signal from Right and Left Head Set (pins 3 and 5) combined through some larger resistors and low pass filter.
5 - Head Set Left
6 - Ground for Head set (grounds 0 and 6 seems to be connected in the subwofer but within the right satelite speaker they seem to be isolated with separate leads to sub)
7 - Power ON/OFF. When OFF or head set jack plugged = 0V; When ON and head set jack unplugged = 5V
8 - 5V Power in
9 - Volume (min=0V; max=5V). It seems they use 50K potentiometer but probably anything >10k should work.
At minimum for standalone sub woofer you will need to implement:
- Power On.Off (switch between pins 8,7)
- Volume control (50k potentiometer (probably anything beteen 10k and 50k will do)between pin 7 and 0 with variable output to pin 9
- Bass control - join two resistors R (I used 7k) and lets call this join point A. Attach other ends of the resistors to pins 3 and 5 respectively. Attach 50k potentiometer (I used 10k) between point A and ground 0. Attach Variable pin of the potentiometer to pin 4 (Bass input signal). Attach capacitor C between Pin 4 and Ground pin 0 (I used Electrolytic 1uF with negative end to ground) . Resistor R and capacitor C should make simple passive low pass filter (Google for formula) that should bypass anf frequency higher than 80-120Hz to ground and feed frequencies lower than 80-120Hz to pin 4.
PS: I managed to hack 251 control satellite speaker to somewhat work with VS 4121 Subwoofer but that is another subject. All electronic parts were salvaged from old broken TV so total cost was $0 but took several days of tinkering for speakers that I could buy used for $10-20 :)
Jun 25, 2012 | Altec Lansing VS4121 Speaker
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
Umm I have an altec lansing vs4121 and the subwoofer is kinda loose so if i get stong bass i hear this extra vibrate in my speakers which is really annoying....
Umm, so what's the question? The sub COULD be damaged or it could be reacting to being overdriven. Sometimes resonances form due to room- or nearby surface interactions. Try moving the sub a foot or two in each direction. Or turn the bass down.
Sep 02, 2011 | Altec Lansing VS4121 Speaker
Is is possible to install altec lansing speakers
It is possible to hook up these speakers to a laptop according to this brochure:
http://www.alteclansing.com/images/spec/vs4121%20sell%20sheet.pdf
Now this manual shows those speakers being hooked up to a computer but laptops have the same outputs as well so here it is:
http://www.alteclansing.co.uk/images/quick/vs4121qcc.pdf
you'll need adobe reader to read the manuals.
May 17, 2010 | Altec Lansing VS4121 Computer Speakers
My speaker altec lansing vs4121 is just humming
Check the audio amplifiers Ic´s maybe are burned
Aug 10, 2009 | Altec Lansing VS4121 Speaker
Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
Speakers
First you may try speakers with another device (like a mp3 player), does it works?
Jun 22, 2008 | Altec Lansing VS4121 Speaker
Lost set up disc
go to the website of the company and just simply type the model no. u will get all the details and u can download a cd content too.....
Dec 03, 2007 | Altec Lansing VS4121 Computer Speakers
158 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
