Question about Welding Tools
No pilot arc, Thermal dynamics cutmaster 50 Need a 12 volt dc signal from U5 pin-12 on the logic card. This sucks because Thermal Dynamics ground the numbers off 5 chips on the logic board. Need data sheets or numbers. No help from Thermadyne. Thanks Manwick
3 Suggested Answers
  • 9 Answers
SOURCE: plazma cutter/no arc
The Cutmaster 50 used two different CD "Capacitor Discharge" Boards. The only ones I have seen a lot of issues with were the smaller ones that are 3.5" X 4"
I have worked on several of the them over the last few months. Even though you might see a spark at the spark gap on the board it might not be sufficient to create a pilot arc.
If your air pressure and so forth are correct your issue is most likely the two white capacitors on the CD board.
Posted on Nov 07, 2009
luis_david
  • 407 Answers
SOURCE: Thermal Dynamics cutmaster 81.
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Posted on Sep 16, 2011
Need an indicate module
Frequently Asked Questions - Signal Dynamics Corporation
www.signaldynamics.com/FAQ/
Our BackOFF brake light modules have a 10AMP limit per output. ... My motorcycle'sbrake light wiring is only a two (2) wire system (power and ground), and the ...
Motorcycle Load Equalizer - Custom Dynamics
www.customdynamics.com/loadequalizer.htm
Motorcycle Load Equalizers & Turn Signal Modules .... signal indicator bulb (the bulb that tells you the turn signals are on) require this kit when Front turn signals ...
Modular Brakeless Deceleration Indicator VoloMOD ...
vololights.com/products/vololights-module
Rating: 4.5 - ‎8 votes
Detects and indicates all methods of deceleration whether engine braking, ... at stop lights for increased visibility; Maintains original aesthetics of your motorcycle ... I havethe Signal Dynamics "Back Off" and that seems to work well as long as ...
Which is the right module for me? - NAMZ . CUSTOM .
Jan 19, 2016 | Motorcycles
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Sep 16, 2011 | Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
The lights are working for power and gas pressure but not the DC arc....BIG Repair problem?????? It a Pak Master 25 Plasma cutter from Thermal Dynamics bought 15 years ago
No, Try changing the tip. The one under thr node cone. If it burns back it will concave and increase the gap between the work and gun tungdten electrode.
Oct 30, 2009 | Welding Tools
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
If you have a old plasma cutter can you swap ot
yes it does matter.each brand is set up for their own torches.
Jul 02, 2009 | Welding Tools
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Welding Tools Logo
176 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
