Question about Samsung Refrigerators
We are contemplating buying a samsung fridge However we currently have a whirlpool with the water filter on it. How would we disconnect the water filter currently installed to connect a new samsung fridge?
  • 21 Answers
I'm not sure I understand your question, so forgive me if I'm incorrect. I'm confused as to wether your whirlpool has an internal filter or if you have an external stand-alone unit.
I have a samsung refridgerator and the water filter is inside the fridge located at the back on the upper right. In fact, all Samsung RAF/AES models come with this internal filter. Depending on where you buy it, often times the delivery guys will set it up for free. They will simply disconnect your old fridge, remove it , reconnect the water hose to your new Samsung and be on their way.
If you choose to do it yourself, simply remove the old fridge, follow the hose to under your sink and remove the old one. Run the new house by attaching it to the appropriate place on your sink and over to the back of the fridge. Also, many modern homes have a cold water tap behind the fridge, so you might be able to connect it there if you do.
Either way, whether you have an external unit or inyernal hose
Posted on Apr 03, 2011
  • Trogs Apr 03, 2011
    Sorry, my phone posted before I finished...
    As I was saying, whether you have an external unit or internal filter, you should be able to just simply replace the fridge and hook it up as it is hooked up now. Many of the couplings and linkages are universal, so you shouldnt have any issues.
    Good Luck.
How can I bypass the fridge water filter on my Samsung RA4287HAR refrigerator?
I know your model is Samsung but on whirlpools when you remove the filter it automatically bypasses the filter through the filter housing I would try that with someone that can turn the water off before you do it just in case I'm wrong about Samsung removal of the filter should allow it to automatically bypass otherwise you will have to buy a I believe a 5/16 Union and just bypass the two lines in and out where you can reach him on the outside
Appliance 911 Sea Breeze
Dec 02, 2015 | Samsung Refrigerators
I put a new filter in my Sansung Refrigerator and the water taste worse than the old one, why?
I agree with Gramps... the system needs to be flushed, but one question... why did you change the filter in the 1st place... was it cause you had a smell or taste in the water AND ice, or the filter light came on?? I would remove water line going to ref from house plumbing... run water in bucket for 2 min, then take a small taste to see if good..If water taste good, then hook water line back up to ref, and run water at the door for about 1/2 gal, then taste and smell water to see if it passes... If still have problem, you are going to have to replace filter head and/or water reservoir.... But before i did that i would contact Samsung to get their take, depending on age they might send parts at no charge to you the consumer....... Ken Hawk
preferred Samsung servicer
Jan 20, 2015 | Samsung RF265AA Bottom Freezer French Door...
I have a Whirlpool fridge that needs a new water filter. Twice now, when I remove the filter to change it, water gushes out even though the ice maker is OFF. I quickly turn off the water line and mop
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Jan 29, 2014 | Whirlpool Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Change water filter
You can check the local Home Depot or Lowes if you have one near by.
Both have a good selection of filters for refrigerators.
Another good online source can be found here.
Oct 18, 2009 | Whirlpool Refrigerators
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Refrigerators Logo
121 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
