Question about Bugaboo Cameleon Stroller
The plastic brake thing on the handle has broken, where or how can I replace this?
    Guru:
  • 541 Answers
Bugaboo don't sell this as a part. If your Bugaboo is under 2 years old Bugaboo will give you a new frame. If older you have two options maybe three: 1/ Check out eBay for a cheap frame with a different fault ( I find UK eBay good for this) 2/ Take the lever asembly apart (it's quite a simple unit held together by two screws) and take the broken lever parts to a plastic welder (look in your yellow pages). Yes plastic can be welded.
There are stroller repair places that sell secondhand parts when they have them. BuggyPitStop in the UK and Karlisle's in Austrailia. A google will find them.
Posted on Apr 03, 2011
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
2001 pontiac aztek Has floor mounted shift. Won't shift out of park.
First of all, you are stepping on the brake pedal when you try to shift. Had to ask.
It could be a number of things. I have a 2000ish Grand Am that wouldn't shift. The problem turned out to be the T-handle on the shifter. Most GM shifter handles come off the same way. If there is a rubber/leather boot, pull that down a little to expose a metal clip.
The metal clip can be pulled off straight for\ward (I think), and the handle comes off.
The shifter will be a tube with a plastic rod sticking out of it. Try pushing the rod in, and see if the shifter works. If yes, replace the handle. If not, the problem is probably down in the shifter.
When you step on the brake, there is a cable going from the brake pedal to the shifter. Step on the brake and you should hear something moving in the center console/shifter. If not, the cable could be detached or broken.
The shifter itself may be broken, but that can be tough to get to.
The could be something wrong at the transmission, or inside the trans.
Feb 27, 2011 | 2001 Pontiac Aztek
The brake of my bugaboo frog broke. I had someone watching my son and she broke the brake someone. Is that fixable?. The brake wire that goes from the brake handle to the wheels broke. What could I do?
If it is less then two years old and you have proof of purchase Bugaboo will replace the whole frame. If older you have a problem. What part is broken? Find your nearest Bugaboo agent and see if you can scrounge a broken frame off them for the parts. I doubt they ship the warranty returns back to Holland. If that won't fly try a plastic welder, It won't look pretty but it'll work.
Dec 24, 2010 | Bugaboo Frog Stroller
I need to replace a broken plexiglass dome cover for the webber chill
Buy a plastic cutting board. Cut it into a 16 inch circle and put a handle on it. Works better than original, keeps things colder!
May 21, 2010 | Weber Chill 05-161 Beverage Cooler
Broken plastic window crank handle on Geo Trakcer 1994
get a toyota handle its plastic but its stronger, the metal handle is going to be hard to interchange, the best thing to do is remove your handle and go to a junk yard and see which handles are the same, you can even put your handle on and see if it works on that car, hope this helps.
Feb 05, 2010 | 1996 Geo Tracker 2 Door
Replace emergency brake lever. In a 2008 ford focus
I have the same damned thing and it made the car fail an inspection. The brake works fine, it's just the cheap plastic button that disengages the ratchet that holds the lever broke.
It's like a rally car now (the lack of a lock makes hand brake skids easier).
I haven't found any solutions online, other than replacing the plastic handle and button as one assembly ... but what if something is broken inside?
Jan 26, 2010 | 2008 Ford Focus SE Sedan
Emergency Brake does not work
You handle should pull a cable, you need to see if the cable is moving with the handle, at both ends. (At the rear by the brakes also) Remove whatever covers the handle to see what is moving, or isn't....start here!
Aug 05, 2009 | Hyundai Motor 1998 Accent
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Fix bar brake on homelite timberman 45
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Oct 12, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Jvm 1410 spacemaker xl1400
not the easiest thing in the world to do. From my notes, that requires actually removing that door. ughhh/
Apr 02, 2008 | Microwave Ovens
Bugaboo Cameleon Stroller Logo
211 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
