Question about SuperMicro X8DAH+F motherboard Intel 5520 Category Motherboards
My PC from Boxx 8520 Dual Xeon Processor with supermicro Mother board this is a problem maker system. very poor performance in3dsmax and takes huge time to load and do any thing in max file.If the max file is above 450 mb then its realy horrible to handle the file in this system. Boxx now is a problem maker. ordinary assembeled pc with Asus mother board and core i7 works excellent compare to this
5 Suggested Answers
  • 31 Answers
SOURCE: X7DAE at the time of boot stuck on logo
the broblem is probably your keyboard, since del doesn't work then this indicates that your keyboard could have some wires cut from inside the wire casing due to various reasons or the keyboard plug isn't well attached to the wires or have some bent pins.
my advice : go buy a new keyboard.
Posted on Dec 22, 2007
  • 10406 Answers
SOURCE: The mother board will not post nor will the
Is the on/off button on the front of the computer-casing broken?
Take a volt-meter, and run a continuity-test.
Are the two wires from that button both properly connected to a pair of pins on the motherboard? If you disconnect the wires from those pins, and use a metal screwdriver to very briefly "short" the two pins, to simulate the pushing of the ON/OFF button, does the motherboard post? Do fans start to spin, or at least "twitch" a few degrees?
Have you tried a different power-supply?
Is there any lamp on the motherboard that lights-up anytime that
the power-supply is connected to AC power? Is that lamp on?
Posted on Nov 19, 2009
  • 191 Answers
SOURCE: I have 946 GZ motherboard graphic card is nvidia
I found a newegg review saying that USB ports stop working and it is a defect of this board. Try to contact support and get it RMAed good luck
Posted on Mar 03, 2011
  • 27725 Answers
SOURCE: I have a server mother
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Posted on Apr 21, 2011
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Need Working X5DA8 Motherboard
Skip the Supermicro board. The cheapest used X5DA8 available at the moment is $800. If you need a dual Xeon capable motherboard, go with Asus Z9PE-D8 WS SSI EEB. It's cheaper and runs faster DDR3.
May 09, 2013 | SuperMicro Computers & Internet
SuperMicro X7DB8 - upgrading from two dual core to two quad core CPUs , carefully installed the quad cores and duct taped it all back together ... no post , no anything ... havent connected a speaker...
SuperMicro Support > SuperMicro X7DB8 Server Motherboard > Main Support page,
Motherboard User's Manual download page,
[ MNL-0832 (English) ]
Dual Intel 64-bit Xeon LGA 771 Quad Core processors, or Dual Core processors, at a Front Side Bus (FSB) of 1333Megahertz, or 1066MHz, with a system clock speed of 333MHz, or 267MHz."
(266MHz geez)
Intel 5000P (Blackford) motherboard chipset.
BIOS should automatically recognize the new processors.
Sometimes you have to restart the computer, and it may be up to 4 times.
Do agree with Jose though, and you may have to go into BIOS Setup, and set the parameters for the Processor (CPU), manually.
1) What is the sSpec number on the top of the processors?
2) Have you been FOLLOWING Anti-Static Precautions?
3) You are scaring me. What is the reference for the DUCT TAPE for?
4) No post?
Better make sure the Power Supply is good, and I mean test the three main voltages. Do not assume because fans spin, or LED's light, that the Power Supply does not have a weak voltage power rail.
(An economical multimeter around here is $5 to $12)
Does the Power Supply have enough power for TWO QUAD CORE processors?
Looking through the charts at the Core technologies listed, you can see SOME of the models can use Up To 150 Watts EACH.
(TDP. Thermal Design Point. W = Watts)
Means to me you better have at least a 500 Watt power supply, and I could be seriously underrating.
Better than an intelligent guess,
[Yeah, okay. Maybe 'intelligent' is going overboard, lol! ]
5) Have the 4-pin ATX +12 Volt power cable attached to the motherboard, (By the 24-pin ATX main power cable connector), and the 8-pin EPS +12 Volt power cable? (Top right corner with motherboard installed in case)
6) Suggest speaker for BIOS Beep Codes, otherwise you are 'Flying Blind".
7) What kind of Thermal Paste are you using, and how did you apply it?
Not trying to be an ar-se, but if you do not answer all of my questions, do not bother to post back.
Post in a Comment.
Oct 16, 2012 | SUPERMICRO INTEL Eatx Mbd X7db8 5000p Dc...
Supermicro x6da8 won't post. Can't get into BIOS either.
disconnect all power connections to the board and take the battery out for a few minutes and then put it all back and see if you can acess the bios. If you still cant, try a bios flash and if that brings you no joy, board is done
Jun 27, 2009 | GE Supermicro X6DA8-G E7525 EM64T S604...
Supermicro X6DAL-TG boot problem
I have 3 of these boards; however, they all have the Nocona Xeon with a Front Side Bus speed of 800MHz. The manual does not say anything about using a 533fsb. A second thought was if your power supply is an ATX with a 24 pin power connector and two +12 connectors one 8 pin and one 4 pin? The manual states all three need to be connected for the Xeon Processor.
Mar 30, 2009 | SuperMicro X6DAT-G Motherboard
All major motherboard manufacturers offer this support on most boards. The em64T indicates the processor is capable of running 64-bit operating systems and software. Do you already have a processor and if so what model is the processor? Based on the processor model you'll need to select a motherboard that has the correct socket type and bus speeds.
May 02, 2008 | GE Supermicro X6DA8-G E7525 EM64T S604...
SuperMicro X8DAH+F motherboard Intel 5520 Category Motherboards Logo
116 people viewed this question
Top SuperMicro Computers & Internet Experts
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
