Question about Bachmann Easy Command Dynamis Wireless DCC Controller
Hello Concerning Dynamis DCC E-Z Command system, there appears to be no infra-red signal between command station and handset, zero level indicated on handset LED (right hand corner) - otherwise handset batteries new and other functions, whilst ineffective are 'working'/indicating. Single green light flashes at Command Station confirming no signal (STOP button on handset has been pressed/reset). Command Station is connected by green connector block and bare wires to Peco track but no shortcircuit on track. First time use of system. So how do we fix the signal - manual refers to possibility of command station and handset not being on same channels - so how do i check / change? I assume there is no way of bypassing the IR with a line connection? Many thanks James
2 Suggested Answers
SOURCE: I have an HO scale
Check the engine motor and second car motor with a digital multimeter for continuity. Make sure the track is connected properly. Also probe the transformer and see if it is sending out power to the track
Posted on Dec 20, 2010
When trying to give a decoder a new address i keeps coming up error code 12how do i get around this
this might be due to electrical "noise" on track or near by , me I use a one piece dedicated track with its own power supply to power my dcc stuff when programming them , if your not in that position financially then try using a short one piece of your own track that doesn't have ends or go anyplace , also try to avoid programming near floursent lights these things throw out tons of electric noise !! and it drives my command system nuts sometimes
Dec 03, 2015 | Bachmann Easy Command Dynamis Wireless DCC...
No power to track
I would suggest that the controller is correct and there is a short circuit. If this is so then there would not be any power on the track. Check the wiring from the controller to the track.
Oct 11, 2012 | Bachmann Ez Command Dynamis Wireless...
I AM UNABLE TO RECORD A PERSONAL MESSAGE ON MY DECT 1580. THE INSTRUCTIONS ON PAGE 11 STATES "1. SELECT COMMAND 8:RECNEWGREETINGS (RECORD NEW GREETING." WHERE IS" COMMAND 8? OR HOW DO I...
On your handset, press the Mute (the button also has an envelope to indicate messages). Press 5 on the handset to stop the playback of messages (if any are on the machine). When the handset beeps, press 8 on the keypad of the handset. When you hear "Record greeting", then speak your message. When you are done, press 8 or 5 to stop recording.
Note the answering machine must be on before you start. Press the On/Off button on the base.
I hope this helps.
Jun 16, 2011 | Uniden Cell Phones
How do I access messages when I am not by the phone?
nschutz,
Remote Operation
You can operate your answering system from a remote location (when you are away from home, or from another room using a handset).
Use this function to check for recorded messages, to play or delete message. When using any touch-tone telephone, you can even record a new greeting message.
Remote Access away from Home
You can operate your answering system from a remote location using any touch-tone telephone.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code
3) The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
*For Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, enter the command again.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering system automatically returns to standby.
0 then 1 Repeat a Message
0 then 6 Answering System On
0 then 2 Play Incoming Messages
0 then 7 Memo Record/Stop*
0 then 3 Skip a Message
0 then 8 Greeting Message Record/Stop*
0 then 4 Delete a Message 0 then 9 Answering System Off
0 then 5 Stop Operation
1 then 0 Voice Prompts
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the number of messages stored in memory. You hear "To play incoming messages, press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Respectfully,
Adam04
Feb 28, 2011 | Uniden Cordless Phone EXAI985
How do you find the zeros of a function on a TInspire
Turn calculator. Use arrow to highlight the 2:Graph and Geometry application. Enter your function at the bottom of the screen. Use TAB to move focus on command line.
Press [ENTER] to graph.
While graph is drawn, press [menu] key. Select [5:Trace][1:Graph Trace] . An X appears on the graph screen. Use arrow to move cursor towards one of the zeros you see. At some point the calculator will pop up the label [zero]
Press [ENTER]
Use arrows to move the cursor near a second zero. When [zero] pop up text appears, press [ENTER]
The value of the secon zero is also displayed.
You can also the nSolve command
Use the nSolve( function available in main calculator application. Here some exemples of syntax
On the second command line, the small vertical segment after the right parenthesis is accessed by the key sequence [CTRL] [infinity, beta, degree] key, the one under [left arrow/clear].
Hope it helps.
Oct 26, 2009 | Texas Instruments TI-Nspire Graphic...
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
time from the chart above.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
TV does not respond to remote commands. Remote has been verified to work as I am able to control my other LG TV. Tried a universal remote and still no response.
Then it is likely that the infra red receiver in the TV set is faulty - or possibly the 5 volt supply to the receiver.
The signals from the infra red receiver usually enter the system control integrated circuit. So if other control functions are working ok this is likely to be good.
It is possible that other equipment can block the remote signal - if another remote controller is stuck on [jammed down a crack in the sofa] or if you use energy saving lamps in the same room - they can produce high levels of infra red noise.
Please take time to rate my assistance - I hope it is useful.
Mar 22, 2008 | LG 42PC3DC 42 in. Plasma HDTV
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
Additionally, you can turn On or Off your answering system remotely.
1) Call your telephone number and wait for the system to answer. If the answering system is
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
4) Enter a command within 15 seconds, each command there after must be entered within 2
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
chart above.
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
telephone.
on page 25).
Oct 23, 2007 | Uniden TRU8885 Digital Answering Machine
Bachmann Easy Command Dynamis Wireless DCC Controller Logo
248 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
