The local drive disk D is closed or it appears just it locked
  • 27,725 Answers
Usually D drive is a cd/dvd drive C: drive shoul be your operating system drive unless you have partitioned your hard drive
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 03, 2011
Fantom drive volumeSerial No.12072
Disconnect the external firewire drive. Start the Disk Utility app in the Utilities folder inside your applications folder. With the Disk Utility window open, connect the external drive and power it on. It should appear in the left column. If not, your drive has probably failed and may have to be replaced.
If the drive appears, select it, click First Aid, then Repair Disk. Wait for this testing and repair to complete. Any problems should be resolved. If the display indicates irreparable disk problems, you may be able to use the Erase function to reformat the disk - but you will lose all the data on it. If repair seems to work, select the drive in the left column and click Mount in the toolbar. From the desktop, open the drive and see if data appears to be accessible. If so, close Disk Utility, restart your Mac and see if the external drive seems to work (repairs can cause some loss of data, but generally you won't be aware of the loss).
If you don't do so now, you should set up a backup of anything you don't want to lose (and we recognize you might be using the external drive for Time Machine). Disks crash and die. You should have a good backup when they do. Time Machine is your friend. Use it.
Jul 01, 2013 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Tip
How to recover data from a bad HDD
<p>If a hard drive clicks and the information starts to move through them very slowly when it opens is stored, you need to store data as soon as possible. It's just a matter of time before the hard disk stops working completely. You can try everything from the freezer to remove the device, because the drives read better in colder temperatures. <br /> <p><br /> <p>1. Place the hard disk in a zip lock bag and freeze the zipper to close. <br /> <p><br /> <p>2. The bag containing the hard drive in the freezer. Cool in the freezer for several hours. <br /> <p><br /> <p>3. Remove the bag from the freezer. Remove the hard disk of the bag. <br /> <p><br /> <p>4. Connect the hard drive of your computer, connect the two pin connectors in the slots of the rear disc. <br /> <p><br /> <p>5. Click on the blue circle in the lower left corner of the screen. Click My Computer. Double-click the hard drive appears. <br /> <p><br /> <p>6. Click and drag the files from your hard disk to another disk or desktop. <br />
on Jun 22, 2011 | Computers & Internet
Tip
Reset Windows 7 Password With Own Created Reset Disk
How to Reset Windows 7 Password
It is easy for you to create a password on Windows 7 to protect computer data. At often as you might forget Windows 7 password, which may result in serious data loss. In reality, forgetting Windows 7 password is not a big problem as long as you create a Windows 7 password reset disk in advance. A Windows 7 password reset disk can help you easily reset Windows 7 password when you are locked out of computer.
Part one: Create Windows 7 password reset disk
Before creating the password reset disk, please insert a USB flash drive or floppy disk in your computer.
1.Click Start button to select Control Panel.
2.Click on User Accounts and Family Safety, and then click on User Accounts.
3.Click on Create a password reset disk on the left of the following screen.
4.Click Next when the forgotten password wizard welcome screen appears.
5.Select your target device to create the Windows 7 password reset disk.
6.Type current user account password.
7.Click Ok when the password reset disk is created.
8.Click Finish when the completing screen comes up.
When the Windows 7 password reset disk is created, a file named userkey.psw will appear on your USB flash drive. Please remember to place the USB flash drive or the file in a safe place. Anyone can use it to reset your Windows password with it if he can get physical access to it.
Part two: Reset Windows 7 password with password reset disk
When you forgot Windows 7 password and locked out of computer, you can take out of the password reset disk to reset Windows password. Plug your password reset disk in computer, and then follow the below steps for Windows 7 password reset.
1. Log on your computer with the target Windows account.
2. Enter a wrong password in the welcome screen password box, and hit Enter.
3. Click OK when the message that the user name or password is incorrect comes up.
4. Click on Reset password on the following screen.
5. Click Next when password reset wizard welcome screen appears.
6. Select the target password reset disk and enter Next.
7. Enter and confirm your new Windows password and click Next.
8. Click Finish to close the wizard.
9. Log on Windows 7 with the newly reset password.
If you forgot to create Windows 7 password reset disk before locked out of computer
A windows 7 password reset disk can really save you a lot of trouble when you forgot Windows 7 password and locked out of computer. So don't forget a password reset disk before locked out of computer. If you forget to create Windows 7 password reset disk, you can use Windows Password Breaker Professional to help you reset lost Windows 7 password. This safe and reliable Windows password recovery software allows you to burn a bootable CD/DVD or USB flash drive to rest lost passwords for Windows 7/Vista/XP/NT and Windows Server 2008/2005/2000. You can log on your computer again within 5 minutes with this tool.
on Oct 29, 2010 | Computers & Internet
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
How can I defrag my Dell optiplex760?
How to Defrag a Dell Computer
1. Open the My Computer window. To do this on a Dell computer, click on the "Start" button at the bottom of the screen. Then, click "My Computer".
2. Choose the hard disk drive that you want to defrag. Locate the section entitled "Hard Disk Drives." In this section is a list of hard drives on the computer. For most Dell computers, the hard disk drive you will want to defrag is Local Disk (C:).
3. Right-click on the hard disk drive you want to defrag on the Dell computer. If you want to defrag your C: drive, then right-click on "Local Disk (C:)". A menu bar will appear.
4. Click on "Properties." "Properties" is the last option on the menu bar. This opens the Local Disk (C:) Properties window.
5. Click the "Tools" tab. The Tools tab is the second tab in the Local Disk (C:) Properties window. The tabs are located on the top of the window.
6. Click the "Defragment Now" button. The "Defragment Now" button is in the Defragmentation section of the window. This opens the Disk Defragmenter window.
7. Click to select the disk drive you want to defrag on a Dell computer and then click "Defragment." For most Dell computers, this will be (C:). After you click "Defragment," the Dell computer will first analyze the disk drive you selected and then beginning defragging the Dell computer.
8. Wait for the "Defragmentation is Complete" message. If you have not defragged a Dell computer in a long time, then the defragging process might take a while, even as long as an hour for very fragmented Dell computers. Allow the Dell computer to run the defrag until the process is completed. You will know that the Dell computer has completed the defrag process when the "Defragmentation is Complete" message appears.
9. View the defrag report and then close the window. If you want to view the defrag report, click "View Report." Otherwise, click "Close" to close the window.
Jun 26, 2011 | Dell OptiPlex 760 MT Desktop Computer
Where TO DOWN LOAD SOFTWARE FOR MY DRIVE MODEL GSL-T21N. DRIVE WORKS In MY other laptop and in this one, dell inspiron 1525, dvd cd drive only open and closes. doesnt appear in My Computer Drives. I want...
> it does not appear in "My Computer"
Does it appear in "Device Manager" with a "yellow-triangle" or "red-X" superimposed on its icon?
Since the tray opens/closes, it is getting electrical power.
Do you hear the drive spinning a disk, when you close the tray?
Sep 15, 2010 | Hitachi Computers & Internet
My Dell Inspirion 2200 doesn't find my peripheral drive no more. When I go to my computer the drive doesn't even appear. I've had it for 2 years now it doesn't appear anymore. I might have dropped it last...
if the drive is dropped then most probably the internal disk is got cracked.due to this its not showing up. but if the drive is just not getting detected in your pc. but the internal disk is not cracked.then you can recover the data.you will just have to take the drive to local pc hardware/software repair maintenance shop. they have a software .that software is called "DATA RECOVERY" software. if the drive is not faulty but just not getting detected then they can recover the data. but if its faulty the data is gone. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 09, 2010 | Computers & Internet
Kingston pen drive locked by LOCKv116.exe
i have same problem with kingston 2GB, i format my pc, also with pen drive attached , now it saying please insert message but pc will detect it
Feb 07, 2008 | Computers & Internet
Acer 5510 notebook Matshita UJ-845D DVD/CD-R Writer Problem
Unfortunately there are no updates available for the UJ-8xx series (except for Sony - which won't work on other machines) as it just uses an old generic Windows optical device driver.
Your problems lie elsewhere.
These units have very very very strong region restriction - no reported patches or fixes that I can find...
So they come with an original region (the local one for where you bought the laptop) set by the manufacturer. You only have 5 possible region changes before it locks on to the final region permanently*.
There is very little info on the Matsushita (now Panasonic) website - but it appears that when you insert a different region disk into the drive it will automatically change the region restriction setting to that new region (and there goes one of your 5 allowed changes??).
If this is correct then you may start with for example a region 2 restriction (whatever the local region is for your computer) and record various DVDs in region 2 format. Then one day you try (deliberately or accidentally) a region 4 disk. Your drive reads it and changes the default to ... region 4 (using one allowed change)... next you put in one of your old disks - and the drive restriction default is changed back to region 2 (using another of your 5 changes) - until you've used up the 5 changes - when it's locked.
Because it's an odd number, chances are you'll end up with a permanent non-local region restriction...
* and Panasonic/Matsushita will only change it for a cost apparently...
so not very good news...
To help you, try this handy little free tool. It will tell you whether your drive is restricted, which region it's currently set to; and how many changes of the 5 you've already used:
http://hijacker.rpc1.org/discinfo/#Download
now if I could just find out how to change the current region...
Jan 13, 2008 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
PANASONIC dmr-es10
The DVD RAM drive is mis-aligned and does not load the disc correctly.
contact our local service center for a quote
Dec 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
