Question about Breville Die Cast 800ESXL Espresso Machine
Where in new zealand can i get a Wand Seal Kit for my 800es Please
  • 3 Answers
You geta blo...............u tell me
Posted on Apr 03, 2011
Will my garmin approach s1 work in New Zealand. It was purchased in Canada?
The GPS will work anywhere in the world but you have to have New Zealand courses installed. There are NZ courses available:
https://sites.garmin.com/clsearch/intosports/golfcourse.html
...but not owning an "Approach" GPS, I cannot advise on obtaining and uploading the required data to this piece of kit.
Nov 20, 2016 | Garmin GPS
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Melted the milk frothing wand in the dishwasher where can i get another - new zealand
In the search bar at the top of your screen, type in Graggia Evolution and take your pick of the return results. You should be able to find a source.Good Luck _Ned_
Nov 01, 2009 | Gaggia Evolution Espresso Machine
Motor starts and pump is not working. No water is flowing at all..what do i need to do?
Water is supposed to flow slightly through the pump without it running so disassemble the wand and cut on water supply, see if water comes out of the wand on-off handle. The motor does not have to be running. Got water flowing? YES - clean out the wand filter or nozzle hole. A partially clogged filter will prevent hi pressure activation.
NO? disassemble pump and clean out chamber paths.
Also - A pressure pump is not suppose to be running and not used for over ten minutes. The pump can overheat from lack of water passing through and damage the pump seals. A clogged wand is the same as not using it while you try to figger out why it doesn't have high pressure. I found my clogged filter and stopped up nozzle but haven't gotten my real high pressure back yet. Sears doesn't sell the valve seal kit but someone does.
May 04, 2009 | Garden
I have a Breville ESP6 Espresso Machine which needs a new steamer wand. The seal on the screw in part at end has gone and the thread is gone too. Water spurts out between the wand and the screw in knob -...
The wand is relatively easy to remove. Thing is whether you have the right tools. If you can find stubby phillips and flat screw drivers, the job will be much easier.
You first have to remove the trim that surrounds the pod and where it covers part of the wand.
The wand is held down by a flat-headed short screw. It might take a few tries to remove this screw due to calcification over the years. Once removed, the wand should just slight out. Check if the o-rings need to be replaced as well.
Mar 05, 2009 | Breville ESP8XL Espresso Machine
F&P Intuitive WM. Needs Bearings and seals replaced
Hello you can get the parts from any New Zealand F & P service center( $50-80nz). You need a special F & P tool kit (you can buy for around $100nz from F & P also) to remove the seal and bearings and to insert the new. unless you know an appliance tech or have a service manual it could be a tricky one. cheers
Please Rate my Advice
thanks
Steve
Feb 22, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Jan 29, 2008 | Saeco V-spresso Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
88 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
