Question about Vulcan GCO2D Gas Single Oven
Convection oven single,table top
My oven will not heat up. pilot is on,all lights are on.Oven is about 20 yrs old.
Got it,thank you
Posted on Aug 06, 2008
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
DEBIG24SS Gas Single Oven: oven want stay on after you let loose of the ign...
replace the gas safety valve thermocouple,it has a thin coil of copper colored tubing going from the safety gas valve into the pilot light flame and as the flame heats the copper tube end it keeps the gas valve open to supply gas to the unit,they get old from being in a flame and cant signal the gas valve to stay open any longer,they just unscrew out of the gas valve and the opposite end is positioned in the tip of the pilot flame to heat it
May 18, 2010 | DeLonghi DEBIG24SS Gas Single Oven
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
My covection oven does not heat up once food is put in
on the gas valve there is an adj. for the pilot size, maybe too small , would try increasing the pilot and see what happens.also the thermocouple might be on the way out ,you might want to replace that and try oper. go with thermocouple first, then try pilot size dont forget to vote tks. monomoy
Feb 20, 2009 | Hobart HGC202 Gas Single Oven
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Vulcan GCO2D Gas Single Oven Logo
151 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
