Question about EA Sports Cricket 2005 for Windows
Wanting 2 know if ticking the red x in batting weakness in create a player will it make the player better or worse ? Thanks tane
  • 255 Answers
It will make the player worse,as you are selecting a weakness by ticking the red cross.
Posted on Apr 03, 2011
Tip
Folder lock
<span>1.Suppose you have a folder named abcd in D:\abcd.<br />2.In the same drive next to the folder create a new notepad <br />file with the exact statement<br />ren abcd abcd.{21EC2020-3AEA-1069-A2DD-08002B30309D}<br />3.Now save this text file as loc.bat<br />4.Create another notepad file and type<br />ren abcd.{21EC2020-3AEA-1069-A2DD-08002B30309D} abcd<br />5.Save this as key.bat<br />6.Now there are two batch files . Double click loc.bat and your<br />folder will change into Control Panel and its contents cannot be viewed .<br />7.To open the folder double click key.bat and you get back your original folder .<br />8?For more safety keep the key.bat in another location .<br />Only for unlocking copy paste to the original location and double click</span>
on Apr 04, 2011 | Computers & Internet
Canyou help? My portable Philips dvd player won't read the discs and does a tick tick sound when on?
Hi,the problem is from the lens of the DVD player,it's either dirty or weak,however,this lens can be cleaned with the use of damped cotton wool and spirit or alcohol.
Thanks and take care
May 12, 2010 | Philips DCP855/37 Portable DVD Player
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
Timer doesnt tick but works if moved manually
The timer has come to the end of it's serviceable life. Being mechanical, they wear out and are not designed to be econonomically fixed.
It needs replacing.
Regards
Jan 14, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
It only ticks when i first start it. after it heats up the ticking gose away and the car runs great! i have added the stuff to my oil that is supost to stop the tick... dint work. any ideas??
Try 5w 30 synthetic oil and some marvel oil. Ticking is likely a lifter...as long as it dosen't get worse, it should be OK the way it is and using oil I said may after time get it to quiet down.(took time to get that way and takes time to get it better) If it does get worse, it will need replacement.
Aug 02, 2009 | 2004 Pontiac Grand Prix
1997 BMW316 compact wont start. Had to jump start it with leads recently but put it down to weather. Only use it during weeks so sometimes left a few days without driving. It ticks when trying to turn...
probably not starter but weak battery when battery low on charge you will hear solenoid on starter clicking when trying to start battery on cars do lose charge in frosty weather but it means battery old or cells in bat inop just replace bat
Feb 21, 2009 | 2001 BMW 5 Series
Wanting to play WMA extension on this Philips Player
There are a few different possibilities.
1)Your subscription to your digital music service such as Napster, etc has expired. Sorry - unless you renew your subscription, you will not be able to play these songs again.
2) Your songs have DRM-encryption on them. To check and see, right click on an individual song name in Windows Media Player, and click on "License" or "Digital Rights"; if the affected songs have DRM encryption, then get DRM-removal software.
3) Your songs do NOT have DRM-encryption on them. In this instance, follow the procedure for item#2, except click on the link in the License or digital Rights tab that says "acquire license" (make sure you are connected to the internet first).
Nov 19, 2007 | Philips SA220 64 MB MP3 Player
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
EA Sports Cricket 2005 for Windows Logo
464 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
param99
Level 1 Expert
Tony
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
