Question about Jeep JX-CHR Boombox
. Plugged it in and
  • lopeka
  • 4 minutes ago
That was a long time ago, 2008, but as I remember I went Through KNG America and purchased a new sound board for $28.00. U will have to have a solder gun and remove the old board and solder in the new one. It totaly fixed mine works great. Here is a link, as I recall I asked to talk to tech support, give the make model # ect of the radio, explain the prob, and ask for a replacement sound or tunner board( I can not remember what they called the part) http://www.manta.com/c/mm7jbzb/kng-america In the event the link dose not work there phone # is (631) 389-5642. PS. kng stands for Kash N Gold Ltd, if u need to do some searching. Good luck, Hope I was of some help.
Posted on Apr 20, 2011
Why is SSB reception (volume) extremely low?
If you have AN RF gain knob on this radio then turn it wide open.
Feb 12, 2016 | Radio Communications
How can I set the volume to low when I first turn my radio on it always seems to revert to high volume ?
Could be a bad volume switch . turn the radio on with the volume low and the squelch knob to see if the audio goes away. If not change the on/off switch .
Dec 29, 2015 | Radio Communications
Receiving volume is very low, I have to turn the volume up all the way to hear anything (squelch is very low when I turned knob to readjust settings) when before I didn't even need to turn it up halfway to...
was the radio wired direct or with a cigarette lighter plug? try the RF gain knob and the mic gain knob.If they are wide open does the radio rec.any better? if not you may have a problem with the main IC
Jan 04, 2014 | Cobra 29 LTD CB Radio
Replace the volume control knob on my radio for 1997 camry
I have a question. I own a 1997 Toyota Camry. the on off controls for the stereo is really messed up. It is really loose to. But you can be driving down the road and it will go from low volumn to high volume. If I hit a bump or turn a corner it will either get louder or softer. What can be done.
Dec 26, 2013 | 1997 Toyota Camry
Acura tl 04 radio volume at full can barely here it
Just try to spray contact cleaner in it thru volume control knob area by removing knob outward.The proper way is cleaning by spraying in the audio control switch from inside but because it is bit difficult job,Hope it will solve the issue.
Jan 08, 2013 | 2004 Acura TL
1997 bose volume
While radio is turned off spray electronic contact cleaner behind volume knob while rotating knob . Make sure you have rag handy .
Mar 15, 2009 | 1997 Nissan Maxima
How can I increase the volume of the radio
Check the grill in front of the speaker area for debris or plugged holes. Check the transmitting radio for debris blocking the mic hole. When turning volume up on the radio, do not max out the volume knob, back it off slightly for best sound. If these do not help, your radio is probably malfunctioning and needs replaced.
Jan 03, 2009 | Motorola Talkabout T5100 (14 Channels)...
Low volume
You can use a FM modulator and hear it fine through your radio, but then you have the problem of no radio to listen to.........Im lost too.
Jun 23, 2008 | Sanyo NVM-4050 GPS Receiver
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Tivoli iPal
send it back! I have had 2 fail this way.
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Jeep JX-CHR Boombox Logo
480 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
