Question about Sony KP-57WS510 57" Rear Projection HDTV
Mi tv sony kp 57 ws510 no arranca el diodo led parapadea 8 veces ,el audio se escucha fugasmente
SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jul 02, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Posted on Aug 27, 2007
ladywinn
  • 5138 Answers
SOURCE: Sony TV Repair
It is really hard to say what could be your problem, so let me know exactly what it is -Does your set play-and has no sound and can you go into menu to audio?let me know i will try to help you.Thank You for using FixYa and Have a Nice Day
Posted on Feb 05, 2008
SOURCE: Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
SOURCE: LA consola arranca , y se escucha el sonido PERO NO SE VE
la buena noticia es que sirve todavia y solo es un problema de video.. tienes que quitar el ps3 todos los cables de atras y volverlos a conectar despuyes de un minuto y si es posible conectalos en otro input del televisor.. si no cambia el cable por otro.. o tratalo en otro televisor.. por ahi esta la solucion ya me ha pasado antes.. por favor dale click a que mi solucion te ayudo.. me avisas
Posted on Dec 27, 2009
Se escucha pero no se ve
esta el la marca de mi tv westinghouse
Jan 14, 2014 | LG Televison & Video
Necesito el codigo para sincronizar mi control de dish network con mi Tv marca ELEMENT. Los numeros de la parte de atras del tv son 3.2
Hola mi nombre es Kimberly Escobar con DISH Network. Con mucho gusto le puedo proveer la informacion que necesita. Ciertos codigos que se pueden integrar al control para que funcione con su television Element serian 627 and 659. el procedimiento a programarlo seria precionar el boton de T.V localisado en la parte de arriva hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 627#. El boton de T.V debera iluminar en rojo 3 veces. Despues de este procedimiento puede intentar usar el control, no le podemos prometer que controle totalmente su T.V. En este link puede encontrar mas codigos y ayuda programando su control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita mas ayuda o tiene mas preguntas pro favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda!
Feb 14, 2011 | DISH Network IR Remote Control
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
El tv no enciende, solo lo intenta, se escucha un clikeo, el modelo es kdl-32l5000
He tenido el mismo problema varias veces, la tele parece completamente muerta. Es un problema con el modo de ahorro de energía. Si la televisión no tiene señal de entrada en uno de sus canales hdmi o vga, entra en modo ahorro de energía, encendiendo la luz de stand-by. No he determinado en qué situación aparece el problema, pero creo que es cuando, estando en stand-by, se desconecta la alimentación. Para resolverlo, desconecta la televisión del enchufe, a continuación desconecta TODAS las entradas traseras de señal, audio, vídeo, hdmi, vga... todo. Espera unos segundos, enchúfala y escucharás un click. A continuación, debe encender normalmente.
Nov 23, 2010 | Sony KDL32L5000 32 in. LCD HDTV
Mi televisor enciende , pero no se ve la imagen , solo se escucha el sonido , eso a que se debe? por favor ayudenme
mi televisor plasma no se puede ver pero se olle que sera
por favor me pueden ayudar
Nov 11, 2010 | RCA 20F420T 20" TV
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Necesito ayuda ... en espa?ol
quiero saver como conectar mi camara labtec en mi computador HP
Mar 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
