The sound volume is very low and won't get any higher on my mom's 25 " RCA tv
Thank you, but the problem has been solved.
Posted on Aug 06, 2008
Lcd buzzing
sounds like a transformer having an issue either the power supply or inverter. You should be able to isolate which one by removing the rear cover then turning on the cover. ( Dont touch anything when its plugged in and playing just listen to see if you can tell where the sound is coming from.)
Feb 11, 2013 | RCA 42LA45RQ 42 in. LCD TV
The sound from the amp does not match up with the video on the TV. We have 2- 25' RCA jacks, 1 to the "Video" and 1 to the "Audio-R" in the "AV IN 1" section. Are our cables...
If those are rca jacks on tv being used to go to amp ?
Are you sure they are not input TO tv rather than outputs ?
YOu must use the AV out connectors on TV to go to amp.
25 inces is fine.
Please dont forget to vote if you liked my answer
Feb 13, 2011 | LG 42LH50 42 in. HDTV LCD
Sound from tv very low
When asking questions that involve multiple units we really need to have make/model numbers and connection details of ALL the players in the scenario as each one has a role in the audio's pathing and control.
If the TV's audio section and speakers were superior to audio-specific componentry we own, why would we need Hi-Fi? Sometimes the audio from the TV is useful so we run RCA audio cables to the receiver from theTV. In some TV's the TV audio output is Variable according to the TV volume control or Fixed so the external electronics can have a contant signal.
In general, TV-related audio is best obtained directly from the source, not the TV. So your cable/satellite box should have its best audio connection going straight to the RCA unit.
Mar 24, 2010 | RCA RTD317 Theater System
My S Video from laptop works with TV however no sound on TV
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
Aug 28, 2009 | HP Pavilion Elite M9150F Desktop PC
The sound control is set at a super low level...To be loud enough to be heard without a problem at a normal distance, the number on the sound level has to be at 90 or 92..My other tv's the same volume is a...
Have you used the remote that came with the TV to raise the volume? Often, when there is more than one remote, one of them is set too low and all you need to do is use the remote that came with the TV to raise the volume level. Good Luck!
Aug 17, 2009 | RCA 14F514T 14" TV
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
Sound on my rca tv
I wonder if your problem with loud volume occurs primarily on commercial breaks, when you turn down
the sound and then, since the sound, for the program itself, is so low in volume, you have to turn it way
up again to enjoy the program?
If this is the case, and there are no other problems with the set, this may not be the set's problem, but the
fact that commercial material is broadcast at a higher volume than program material by some outlets, so
that while you are in the kitchen, during commercials, the sound of the commercial can still be heard.
Apr 18, 2009 | RCA Televison & Video
No sound
check if u have muted ur sound.....if so just push sound again and it will ur instruction for ur set.....
Mar 28, 2009 | RCA 24V510T 24" TV
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Problem with the volume
what about sound bar in the tv that shows how much is vol.
is it remain normal or go at full ..
check if it remains normal then its another problem
if it goes also full then it might be software problem
Aug 14, 2008 | RCA F25422 25" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
