Question about Eiki LC XG200 Multimedia Projector
LC-XG200 bulbs where can I get one in the UK? At the moment my image looks blurred is that caused by the lamp or is some other issue?
  • 442 Answers
In the first instance:
Adjust focus of the projector.
Make sure a projection screen is at least 4.1' (1.2m) from the projector.
Check Projection Lens to see if it needs cleaning.
NOTE : Moving a projector from a cool temperature location to a warm temperature location
may result in moisture condensation on Projection Lens. In such an event, leave a
projector OFF and wait until condensation disappears.
Posted on Apr 03, 2011
TOSHIBA 57LX177 SHADOW SPOT CENTER OF SCREEN
If my research is correct you recently replaced the lamp and then the "shadow spot center of screen" appeared.
Three possible reasons I can think of for this:
Something wrong with new lamp or on face of lamp--never touch the face of a lamp as oil from you hand can leave a residue and damage the lamp or cause a image issue.
Something inside on the optical lens or even the mirror causing this--not likely but possible.
A defect in the optical light engine in the set---usually if heat which comes from the lamp damages the engine it will be a color and not black---engine has a series of lens and baffles inside that heat can damage--causes minute separation inside of the lens etc.
If the old lamp works at all try putting it back to see if same issue--did you replace just the "bulb" in the housing or the whole cartridge?
If remove new lamp look at it and where it faces--usually a clear lens faces it and if some dirt on that..........
Jun 03, 2012 | Televison & Video
THE IMAGE IS VERY BLURRED!
If there is dust on the lens then that could cause the blurrness. apart from that you may uninstall the driver of the Web cam and install it from the following site.
Click here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=pv-51293-1
Hope this resolves the issue.
Good day.
Aug 13, 2011 | HP EW192AA Webcam
My Eiki lc-x1100 is not displaying very bright. I bought is used from a university and it only has about 900 hrs. on the present bulb. Is there something else that would make it dim? Don't want to...
i would check the physicality of the lamp. once you've removed it, look around the filament of the lamp, and if you notice any dark corrosion build around it, then that's what's causing the dim image. if it looks clean and clear, it might be one of the mirrors within the projector's optical engine.
May 24, 2011 | Eiki LC-X1100 Multimedia Projector
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
Cannot turn the projector on with the remote control
Hello :
read the following paragraphs please :
1:Are the input and output vents blocked or obstructed in any way? That could cause overheating problem and what you see with your projector is one of it's symptoms .
2:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage .After cleaning the filter always remember to reset your projector .
3:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Try removing and reseating the lamp, or to try another lamp.
6:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
PLEASE RATE !
Apr 12, 2010 | Eiki LC XG200 Multimedia Projector
On the left side of the screen the red color is bleeding off the other colors and causing the picture to be blurred. It is not across the entire screen. Just on the left portion. Do I need a new bulb or is...
That is *not* a lamp problem. Definitely sounds like you have a some sort of video processing problem with the red signal. Just to be safe, try a complete factory reset in the menu. Sometimes, the auto-sync and other such functions cause the image to distort. This can happen if the projector is used with multiple image sources and the unit has to resize the image--it does this using mathematical algorithms. If resetting doesn't help, you need to explore repair options...remember, the unit has been around for awhile--shop around the search engines for quotes.
Aug 30, 2009 | Epson PowerLite 5500C Multimedia Projector
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Sanyo projector image problem
Can you describe the issue?
check out fixmyprojector.com
they can fix this problem for you!
Jan 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Problems changing lamp
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
May 19, 2007 | Eiki LC XNB3 Multimedia Projector
Eiki LC XG200 Multimedia Projector Logo
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
