Question about Philips Zenia Voice Cordless Phone
Ringing my CD 235 phone is not ringing out only the cordless extension upstairs is ringing out. I don't use the answer phone and whensomeone rings it lights up but has no sound. I have cheched the volune and tone ect. an ther is no problem any suggestions please.
Hi I just took the batteries out and it sorted itself out, thanks
Posted on Aug 06, 2008
My phone will not ring when receiving calls.
Press Menu. Select "Answering Setup" and see if you can solve your problem there.
Jul 08, 2014 | Uniden Cordless Phone
I want to buy the Canon ImageCLASS MF4350d all in one printer. My main concern is receiving faxes. I have a cordless phone with built in answering machine installed in a phone jack downstairs.. the...
No you cannot do it that way. The TAM (Telephone Answering machine) must use the tad port in the machine otherwise the fax will not detect an incoming ring and the fax switch will not function. Your best option would be to put the master phone with the fax and take one of the wireless phones and put that in its place. the cordless does not have to be in the houses master socket. It will work happily on any extension in the house.
Aug 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Answering system
my answering machine light blinks but the machine isn't working.
Dec 17, 2008 | Panasonic KX-TG1033S Cordless Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Searching for a phone with special feature
Yes you can buy cordless phones with transfer capabilities. We have several of them at where I work.
The unidens are some of the better phones on the market. All we have to do with them is when we receive a call is hit the talk button again and dial the number we wish to send the call to.
Any of the unidens should have this feature you could ask the salesman if you can plug them in to test.
An example of a good phone is:
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2&page=6
Apr 24, 2008 | Northwestern Bell 35828-M2 Cordless Phone
Do not have owners manual
just hit the "int" button in the middle of the handset (above the number 2) and the display should read "Paging Extension?" so then you type in the handset of the other phone. For example, my base station is downstairs (Ext 1) and my other phone is upstairs. I pick up the upstairs phone hit "int", then "1" and the phone downstairs will ring. I believe they are, by default, set to "1" and "2".
Dec 29, 2007 | GE 28112EE2 Cordless Phone
Philips Zenia Voice Cordless Phone Logo
166 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
