Question about Hifonics BXi1608D Car Amp
My hifonics is on and u cant hear bass the red light is not on wat could it be?
  • 447 Answers
Double check your wiring. Make sure all conections are correct. Does the unit have fuses? Check them, replacewith exactly what the unit calls for.
Posted on Apr 03, 2011
How to make a remote bass knob for a hifonics crossover
Bass knobs are just Rheostat "switches" run to a 2.5mm jack.
They are all essentially universal, and you can find them for very cheap, typically around what it would cost to build one.
Mar 17, 2015 | Hifonics Car Audio & Video
Internal fuse
Amps getting power that's good it seems as though either you have a cross in your bridge or you fried your amp
Apr 02, 2014 | Hifonics Car Audio & Video
I have 2 kenwood 3011 400 watts rms and 12oowatts peak power each 1 is blown and wonderin about upgrading 2 the Hifonic Olympus OLM1612 would this be a good upgrade even thought i only a 400 watt kicker...
yea for sure thats a good upgrade. You shouldnt havebeen able to blow the kenwoods with 400 watts though-meaning that they probably blew from distortion which causes heat(fast) Check your gain on the amp start it out at 1/4 gain and turn up your deck to the point where you can hear distortion from your mids and highs or to the maximum level that you listen to your music at. If you're jamming out at a level that is causing distortion then you will be sending a distorted signal to the amp as well. The amp then amplifies the distorted signal through the subs which overheat and blow. So find the distortion spot and then turn it down just a little bit till it clears up your sound-then adjust your gain on the amp up slowly until you cant hear it getting any louder. Once you have done that you have reached the limit of CLEAN power that you are going to get.Thats where you want to keep it. Watch the bass boost too if you have the bass up on the deck and then crank up the bass boost on the amp it really f's up the signal too. Good luck
Jan 31, 2010 | Hifonics OLYMPUS OLM1612 Car Subwoofer
Protect Light problem
I'm having the same problemdid you ever figure out what it was ?
Dec 01, 2009 | Hifonics Car Audio & Video
I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Mar 01, 2009 | Hifonics TX1505D Car Audio Amplifier
Hifonics Nemnsis powerin off.
need to charge you batteries up more bass cuts out because not enough power! i have the same issue! 2 amp slow charge is the best way to charge your batteries!
or caps!
Jan 27, 2009 | Hifonics HFR1 Amplifier Accessory - Remote...
Remote bass knob help
i don't think you'll have any problems if the hook up will fit. i myself have a lighting audio bass knob hooked up to a jensen amp and haven't had any problems from that
Dec 12, 2007 | Hifonics TX1505D Car Audio Amplifier
Power light
This could be a DC offset condition. Check you manual for what this means. Or other condition. First Disconnect the Subs and try it. If it still goes red then disconnect the RCA's and try it again. If the Led continues to go red after the click then the Amp is hosed. The Click you hear is an internal relay that cuts the subs in after a dely so you do not get the turn on THUMP of the radio at your subs.
Jul 08, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Hifonics 1605d stopped working
the red light blinking because your amplifaier its dead look for the alimentation cabel end replace the calibration protector
Apr 16, 2007 | Hifonics BX1500D Car Audio Amplifier
Hifonics BXi1608D Car Amp Logo
104 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
