Question about Jl Audio 500/1 Car Audio Amplifier
Hello, I've Got the JL Audio 500/1 and I am running two 15" Kicker Comps. in a sealed box and bridged to my 500/1 and for some reason all of a sudden the amp now powers off then on none stop. the green power light flickers off and on. I have 4 gauge power and ground wires a new battery and a brand new 160 alternator and this amp is still doing this could any one please pplrase give me suggestions I'd greatly appreciate it thanks
  • 447 Answers
If your sure the unit is getting the correct power, check the ground cable, make sure it is connected to a clean surface. (remove any paint where the ground is connected.) Double check your wiring. Make sure all of your connections are good. Do not forget the fuse holder, check it too.
Posted on Apr 03, 2011
  • oscar willis Apr 04, 2011
    I checked all things you said and it continues to do it. I'm at a loss do you think it is the Amp. now thats the only thing I can think now.
I have two kicker cvr 12s how will I hook them up to hit the hardest with a jl audio 500/1
you would want to bridge them you take 2 pieces of speaker wire long enough to reach each sub and connect one side to the box and the other side of wire to the sub then you take your other speaker wire and hook it up to the sub you already hooked it to then run positive and negative to the other sub
Jul 07, 2010 | Audio Players & Recorders
I have a jl 500/1 pops fuses some times could it be im pulling too much power from the battery because i dont have a cap or extra battery im running at 2ohm with a 15 inch kicker l5
Seems like the KICKER is pulling to much power try to knock it back up to 4ohm and see what happens. If its fine that way then you might need a bigger amp.
Apr 29, 2010 | Jl Audio 500/1 Car Audio Amplifier
I a looking to qire two 10 inch kicker comps what is the best way to get sound out of this set up in a sealed box and kac 7252 amp 1000 watt
check the ohms on the subs if its single 2 ohm make sure you dont bridge it avoid 1 ohm unless the amp is class d duel 2s make 4 or 1 depending on if you series on paralel them duel 4s make 2 ohms or 8 you want to make a duel 4ohm 2ohm and put one on each chanel email me for better exp.
Feb 05, 2010 | Kenwood KAC-7252 Car Audio Amplifier
How do you properly bridge a four channel kicker 350 watt amp? I am running two 10 inch JL audio w1s.
Left ( + ), Right ( - ). If your not sure about Front or Rear.. Then just see where your RCA's are plugged in. Should say Rear Input, or Front input near them.
Jan 17, 2010 | Kicker KX350.4 Car Audio Amplifier
2 L5 12'S 2OHM
I like JL Audio's products and in this case a 1000/1 would match these subs really well considering that each sub is rated at 600 watts RMS. I know that you want to bring these subs to the max and if you're not worried about blowing them up you can use two JL Audio 1000/1's, the JL amps have something called ohm matching and can put out 1000watts RMS at any load between 2ohms and 16ohms. A very use full feature - as well as a subsonic filter that can keep out the bass you can't hear and thus keep your subs alive longer especially if you plan to max em' out. Check out Ebay for good prices on JL Audio. Another choice might be an Audiobahn 2300, or preferably an 1800d. D class amps are best for max output and I've wired an Audiobahn 1800d down to a 1 ohm load (to two dual 4 ohm 15" Cerwin Vega Strokers paralleled down) and it was able to stay alive, but this was not used for prolonged listening (Short bursts for SPL comps). Good luck and I'll leave you with an old trick I used to use on my clients SPL Comp cars. Run an in-line fuse to each sub - start at about a 100amp fuse (1,000w @ 12v = 120 amp draw) and move it up if it blows too early, fuses are cheaper than subs! Let me know what box you are running as it must be built specifically for running the subs all-out. You can e-mail me @ (dynami28@charter.net) for free specs on basic enlosures.
-Dynami
Apr 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Bass sounds muddy and volume is minimum.
Hello mercedesman4,
Your setup sounds great. I had to settle for Blaupunkt in my Mercedes.
It sounds like the culprit is your enclosure. It's possible that by tweaking the settings, you could improve the sound somewhat, but having been used to the sound of a sealed enclosure, maybe not. Sealed enclosures tend to produce tighter, more accurate bass and have a flatter frequency response curve. They are also generally the enclosure of choice when looking for a SQ (sound quality) oriented setup.
Ported enclosures will produce louder bass than sealed enclosures, and maybe that's why some audio guys push them. They also allow the speaker to operate more efficiently, so you need less amp power for a given volume. Higher tuning on a ported box will get louder, but at the expense of sound quality. Lower tuning will still get louder than a sealed box, and the sound quality will be better than a box tuned higher, but still not as good as sealed. That's what I meant about tweaking the settings. You may see some improvement by setting the crossover lower, decreasing bass boost, or by turning the subsonic filter on/off. I'm no audiophile, but personally I've never been able to stand the sound of a ported enclosure, however it was tuned. Sealed just sounds better.
Hope this helps.
Mar 30, 2009 | Car Audio & Video
Box size
http://kicker.com/Product_Manuals/93/104 , look at the tech manual, it will give you dimensions of sealed or vented and it will give you a couple of box ideas.
Feb 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Will this give me what I want
I perfer a sound stream reference 500, it is a great amp. I had 4 Kicker comps 12", and man the boooom. What you have is good, if you have them bridged.
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
500/1 v2 and one kicker VS12L7
It will work fine. This amp is stable to 1.5 Ohms, but is designed to put out about the same amount of power at 2 or 4 Ohms (unique).
Feb 03, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
107 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
