Question about Microsoft Xbox 360 Console
E 74 my xbox got the 1 red light called the e 74 error so wat ca i do to fix that
  • Anonymous Aug 05, 2008
    me too e 74 sucks...
  • 376 Answers
Found this on a forum site hope it helps-
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)-
ERROR 0102 Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
Posted on Aug 05, 2008
1 red light e 74 code
E74 is an error related to video. It's either:
  • Bad video cable
  • Bad graphic chipset issue
Try a different video cable, unplug and plug it back in to make sure the video cable is seated properly. If it's neither of these issues, the only thing to do is to contact Microsoft's customer service and get it replaced/fixed.
May 27, 2010 | Microsoft Xbox 360 Console
1 red light on top right of console when lying flat
if you also get e-74 displayed on screen then the error is caused by an overheated gpu. unlight the 3 red light, this cannot be easily fixed since the gpu is soldered onto the motherboard. i'm afraid you are dead in the water, if you are outside the waranty you might as well buy a new xbox, there's no way to fix this one without replaceing the motherboard.
Aug 14, 2009 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
1 red light e74 error
this is bad because you need to call 1800myxbox and they will fix it in a about a 2 weeks they will send it back fixed the same thing happened to me.thts the only way to get it fixed
Jan 11, 2009 | Microsoft Xbox 360 Console
I have 1 red light
This Sounds like a Error 74 you are speaking of.
This may be fixed for a short time by unplugging every cord from your xbox and leaving it for 30 min to an hour. tho this is only a workaround if it is under warranty i Highly recommend getting it replaced
An e 74 involves the GPU and will require soldering to truly fix and now there are a fuw things you can do one is to call Microsoft and get Assistance by phone
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102
Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
-Or-
Try it your self i do NOT recommend do this as it will VOID your warranty but if you feel compelled to fix it your self
--- I do not accept any responsibility whatsoever on what you do to your xbox - I am just here to inform ---
http://www.youtube.com/watch?v=GTBH29CmFHA
This is a video showing how someone fixed there E74 for the second time. The xbox was reported to be currently playing fine, has a few games of halo 3 online to test and the box worked without any problems :)
Go to xbox-scene.com if you need any other infomation regarding xbox repair.
Good luck with whatever you deside to do!,
-Rel
Jun 01, 2008 | Microsoft Xbox 360 Console
Error 74
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 1 red light
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red light Error) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Dec 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
71 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
