Question about Philips Audio Players & Recorders
I have a Phillips FP9503 turntable. I havent used it for a while, now cant remember how to play vinyl on it. Any ideas?
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: error on the vinyl mode will let me cue but not play
More than likely you have a bad switch, although this is not something that you could service yourself. I would suggest taking it to a service center in your area. Make sure they are Pioneer authorized, and know what a CDJ800 unit is!
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Posted on Jan 17, 2009
STYLUSCITY
  • 271 Answers
SOURCE: Converting vinyl lp's to cd's with same quality
Hi, use acoustica spin it again. You can adjust the input levels and it will convert the records analogue signal to wave format. Cheers styluscity@gmail.com
Posted on Sep 13, 2010
  • 12 Answers
SOURCE: My turntable judders when playing
Check the belt path for any foreign material that may be on the pulleys. Without the belt attached, feel for a rough spot(s) while slowly rotating the platter. Same for drive motor. This will often identify the offending part. With a seldom used table, the grease on the table spindle dries out and may need cleaning with a solvent (alcohol) and q-tips. The same for the motor. Then re-lube with a synthetic oil. Be careful that you don't lose any bearings or spacers. This technique has repaired many tt's. Good luck, work slowly and carefully.
Posted on Jan 13, 2011
Why does the turntable stop and just sit on the record before the record is finished?
The turntable shouldn't sit on the record at all. You'll really damage your vinyl by doing that.
Always ensure that the vinyl disc is placed over the spindle, then rests on the platter so that the stylus can play it as intended.
Oct 02, 2015 | Audio Players & Recorders
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
May 23, 2014 | Marantz Audio Players & Recorders
Rega planner 3
If the amp does not have a dedicated sockets for a turntable - often marked "phono". Then plugging it into an aux socket won't work. You will need to get a Magnetic Cartridge Pre-amp. The turntable plugs into this and that plugs into your aux socket. If at the present you turn up the volume really loud you might just hear the record playing. That will tell you that the cartridge is OK.
Jul 14, 2013 | Audio Players & Recorders
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
I've connected my turntable to my stero system. When I try to play a lp the sound is terrible. I've replaced the needle. Did not help. Any ideas?
is the vinyl clean vinyl is supposed to sound weird thats what its all about. if the records not clean it could make it sound ****
May 21, 2011 | Numark ttUSB Turntable
Convert from Vinyl to MP3
I prefair to use Magix Audio Cleaning Lab to convert records to MP3, It's really good at getting rid of noise and crackles.
Jan 01, 2010 | Audio Technica AT-PL50 Turntable
Error on the vinyl mode will let me cue but not play
- OPTiC
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Jan 16, 2009 | Pioneer CDJ-800 Turntable
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Jan 12, 2009 | Televison & Video
CDJ 800 wont play when in vinyl mode
Well im having the exact same problem and cant for the life of me figure out why it wont work if you have a soulution please please please email me
gasoline@live.co.uk
Aug 25, 2008 | Pioneer CDJ-800 Turntable
101 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
