Question about Nokia N72 Cellular Phone
My screen is blank and i want to turn on my bluetooth so as to backop my contacts.Wat numbers on do i press on the menu to turn on the bluetooth?
I like this phone
Posted on Apr 03, 2011
Will this phone connect with a 2016 Honda Accord EX Sedan
Check your owners manual, does the car have that option. If you still have questions contact the new car dealer.
Aug 21, 2016 | 2016 Honda Accord
Tip
How to turn Bluetooth on and off on a Samsung Intensity
Like many other cell phones, the Samsung Intensity (SCH U450) is Bluetooth-capable. Turning Bluetooth on and off on the Intensity is easy to do, as is configuring the phone's various Bluetooth options and setting up new connections.
To turn Bluetooth on, press the Menu button (the round button in the upper center of the numeric keypad). On the main menu screen, select the Settings & Tools submenu in the lower right hand corner. Then scroll down to item #3 (Bluetooth Menu) and select it.
If Bluetooth is currently disabled, the option in the lower left corner of the screen will say "Turn On." Press the left option button to turn Bluetooth on; you'll see a box pop up that says "Bluetooth power on." Now you can pair your phone with other Bluetooth devices, either by initiating a connection (choose Add New Device from the Bluetooth menu, or if you've paired with the device before, select it from the list of devices) or by making your phone discoverable (click the right option button, select Discovery Mode, and turn it on).
To disable Bluetooth, go back into the Bluetooth menu and just hit the left option button ("Turn Off"). A box will appear that says "Bluetooth power off."
If you're not sure if Bluetooth is on or off at any given time, just look at the status bar at the top of your Intensity's main screen. If you see the Bluetooth icon -- a sharply-angled white "B" on the blue background -- then Bluetooth is currently enabled.
on Oct 16, 2010 | Samsung SCH-U450 Cell Phone
How do i get my bluetooth to work?
Turning Bluetooth On or Off
1. From the Home screen,
press MENU>Settings&Tools>Bluetooth Menu
2. Press the Left Soft Key (Turn On) or (Turn Off).
- or -
press the Directional Key RIGHT, highlight Bluetooth On/Off,
then press OK
from page 101 of your Phone's manual:
Samsung Convoy 3 (Verizon)
http://www.fgcu.edu/Telecommunications/Folders/samsung-convoy-3.pdf
>> If this was helpful in any way, please let me know so that I will continue helping others, by Clicking on the Helpful button below. Thank you :)
Dec 05, 2015 | Samsung Cell Phones
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • From the Menu screen, select Settings
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Dec 31, 2009 | Sony Ericsson K800i Cellular Phone
Emerson bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 14, 2008 | Southern Telecom Emerson Bluetooth Headset...
Connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
Aug 15, 2007 | Jabra BT800 Consumer Headset
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Nokia N72 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
