Question about Microwave Ovens
We are getting E2 error code - Microwave Ovens
  • 1 more comment
  • donevans739 Apr 03, 2011
    The Avanti induction hotplate is part of the Avanti Compact Kitchen CK301H
    The Avanti Induction hotplate is part of the Avanti Compact Kitchen Model number CK30iH
    Yes, Thank you.
  • 8,197 Answers
MAy I get the make and model # to help you more with the code problem. I will also try to help you fix if I get this info
Posted on Apr 03, 2011
  • Jyackle5
    Jyackle5 Apr 03, 2011
    The E2 code means that the heat element has gone bad and nees to be replaced. You need to call 800-220-5570 to order the part and get a service manual.
  • Jyackle5
    There is a heating element under the hot plate to get it hot. That part has gone bad and needs to be replaced to work again.
E 2 ERROR IN SAMSUNG MICROWAVE
E2 is the error code indicating a jammed key
see the diagram and replace.
Feb 07, 2013 | Samsung Microwave Ovens
Error code E1
this type of code normally mean Control Board Problem. You must call to the profesional repairmain. However you can do the following :
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
Sep 16, 2012 | Microwave Ovens
My white westinhouse microve is showing E2 and beeping but not workiing
disconnect by 30 seconds, and connect again. If the problem code appear your must replace the touch pad+control board.
see the diagram
Jul 31, 2012 | Microwave Ovens
What does E2 means in sky line induction cooker
That code on most units means there is a control board error, usually a jammed touch button or condensation etc.
Feb 04, 2011 | Microwave Ovens
Oven code f3 e2 whirlpool
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!@@
Apr 11, 2010 | Whirlpool MH1150XM Convection/Microwave...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
