Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Need to replace a brush belt - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
    Genius:
  • 1,739 Answers
Accessories and replacement parts for your Bissell 1697 Powersteamer Pro are available here:
http://canada.bissell.com/Products/p/powersteamer+pr/ak/replacementparts/Product.aspx
Your User Guide is also available at:
http://canada.bissell.com/images/UserGuides/1697C.pdf
Refer to page 15 for instructions on how to replace your brush belt.
Posted on Apr 03, 2011
Change a belt
You did not state your model or make so I can't explain how to change your model but most vacuums you must remove the bottom plate held on by screws that covers the brush roll, remove the brush roll and belt and reverse the process with the new belt. Some models have the brush roll held in by screws and/or brackets, some brush rolls slide down into slots. Replace the brush roll if the bristles are worn or frayed. If you are not replacing the brush roll remove the endcaps if possible and clear any hair or debris that has worked it's way in there.
Cogged belts are different from stretch belts and do not need to be replaced at least once per year like stretch belts do. You should still remove the brush roll at least once or twice per year to clean out debris. Maybe more often if it gets hair or strings wrapped around it which can build up causing friction and heat which can melt or damage the brush roll or even the nozzle housing.
Jan 29, 2017 | Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
I need to replace the belt on my Riccar supralite vacuum and need instructions
Lay the vacuum upside down, remove the bottom plate, remove the brush roll and belt, install new belt around motor shaft and brush roll, pull on brush roll to stretch belt far enough to drop brush roll back into place.
Aug 14, 2013 | Riccar 8955 Upright Vacuum
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
Hi, I just replaced my belt for my Hoover Upright Futura with replacement belt 38528040. Now it is making a very loud noise with a lot of vibration. What would be the cause? Could it be the new belt? It...
It is not likely to be a belt problem. I would remove the belt and brush assembly, turn the vacuum on, and see if it is still loud. If it is, the motor fan is broken and will need replacement. If it sounds normal, the problem is in the brush assembly. Examine the ends of the brush for damage or play in the bearings. The brush may need replacement ( part # 48414081 )
Jul 26, 2011 | Hoover U5227-930 Elite Upright Vacuum
Is there any reason the water won't come out?
You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
Bissell Powersteamer Belts
Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Vacuum brushes won't turn. It still has suction.
That means that you need to replace the belt that turns the roller brush. They naturally stretch and wear and you should replace this belt yearly. Here is the belt you need and the manual which has instructions on how to change it:
Dyson DC07 Belt and Manual
Dec 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
How to replace belt
Most Riccar's, turn vac over, take off the bottom plate, Brush roll and belt are there. Put new belt over motor shaft, then over brush roll, push brush roll back into place and re-install bottom plate.
Jan 29, 2008 | Vacuums
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
524 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
