Question about Refrigerators
Fridge will not get cold and fan keeps running
    Brigadier General:
  • 3,917 Answers
Hi
It's possible that the compressor is dead or not working properly. Also try to dust off the coils in the back.Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils (under the unit ) for blockage from dust. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please check this link for a detailed article related to your query:-
http://www.applianceaid.com/frig_notcold.html
Also check the bellow link to get a useful article to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsstoppedcompletely
Please get back to us if you have further query else please accept the suggestion.
Posted on Apr 03, 2011
Why is the fridge and freezer not cold enough
If the fan isn't running neither section will be cold enough. There may be something jammed against the fan blade or the motor could be defective.
Jul 19, 2014 | Smeg FAB32RNN 50s Retro Style Black 304 l...
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Freezer working well fridge not working at all
there is a fan in the back of the freezer that pushes air into the fridge side of the fridge it sounds like this has gone out on you. this fan is usually right by the coils in the freezer the only thing that keeps the fridge cold is a little air being pushed over there constantly
Apr 27, 2009 | Refrigerators
Fan running but not keeping cold
check to see if the compressor is running, if not you may need a start kit, (relay,overload) If the compressor is running take the back freezer panel off and check to see if there is a frost pattern, might be out of gas if frost pattern has receeded
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
Fan keeps running
freezer fan runs when freezer calls for cooling
ref fan runs when fridge calls for cooling
condenser fan up top runs with compressor
lower unit condensate fan runs with compressor
fans should not be noisy
control monitors temp and will give alarm if temp rise
please contact viking as your fridge may have a safety recall on door hinges
Jul 03, 2008 | Viking VCSB483 Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
