Question about Kenmore Microwave Ovens
Power connected. where is the microwave / range fuse? on Kenmore model 85710 767-8571000
MicrowaveSvc
  • 9047 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Possible fuse blown
That would be located behind the control panel.
In essence, you unplug the oven, remove the grille from across the front, then you'll see the screw holding the control panel on.
Once that screw is removed, the control panel can be lifted up and out, then you should see the fuse.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
  • 35 Answers
SOURCE: fuse blew microwave
Sounds like a fault on the magetron power supply.
If you are confident enough to ground and discharge the main capacitor, check to see if it is faulty.
Check for arcing or scorch marks around the transformer and check the HV lines on the magnatron input for continuity.
If the capacitor has blown out, this can be replaced, however if the magetron or transformer is faulty this is a much more complicated repair and should only be done professionally.
Posted on Mar 25, 2010
Testimonial: "Thanks for such a timely response."
SOURCE: My panasonic over the range microwave model
I have same problem. Disconnect the power. Take the 3 screws out of the top of vented front thus exposing 2 screws that hold down the touch pad .remove them and move touch pad out of the front and out of the way. on the extreme top right within the compartment there is a circuit board that has a fuse on it. replace the fuse and try to restart the microwave. if the fuse blows again you have a major problem probably the magnetron. If you need further help call me (403)870 9110.........Ron
Posted on Apr 30, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: trying to change a fuse on microwave.
It may be the fuse or the thermal cutout / thermostat associated with the magnetron.
You say you have the service manual? If you mean the folded-up "mini-manual" that should show the relative locations of the parts in a perspective view.
Also, you can find exploded views at the Sears parts site.
Looking at the "interior parts ii" exploded view here, it shows the fuse (drawing reference # 5001) on the small RF noise filter board located on top of the air duct assembly.
You'll need to remove the oven from the wall to get to it for testing & replacement.
The installation instructions are handy to pull the oven from the wall.
If you've misplaced yours, the Sears site may have them free.
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on May 30, 2010
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Kenmore microwave 80404400 no power
This is typical of the 20 amp fuse blown. It can blow due to slamming the door or even opening the door to quickly while it is running. It could also blow if there is a failure of one of the door interlock switches. This fuse is ceramic and looks similar to a cylinder automotive fuse and is located behind the control panel on this model.
Apr 20, 2010 | Kenmore 80412 Microwave Oven
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
No power-fuse and outlet are good on model 665.69689992 over the range unit.
your microwaves internal 15 or 20 amp ceramic fuse must have blown,unplug and remove outer cover be sure to discharge hi voltage capacitor with insulated screw driver,then it will be a fuse with a white colored body in a clip mount,remove and your local hdwg store has them, if new one blows then either the h.v diode/cap/or magnetron or theres a bare wire shorting to ground,you will need an ohmmeter to diagnosis this
Aug 23, 2009 | Kenmore Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Apr 02, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
