Question about Kenmore 25862 Top Load Washer
HOW OLD IS A KENMORE MODEL 25862
HOW OLD IS THIS MODEL KENMORE MODEL 25862
  • DEVIL68 Aug 05, 2008
    CAN ANYONE TELL ME IF KENMORE MODEL 25862 IS A GOOD MODEL AND HOW OLD IS THE MODEL.
I bought my model 25862 in May, 2005. The only thing that has ever gone wrong is the plastic gear that runs the agitator on heavy duty broke. My husband ordered and replaced for under $30.00
Posted on Nov 29, 2008
How to remove top of washer ?
This assumes that you have a basic top load / direct drive washer:
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
Some versions of these washers do not have removable end caps.
In that case, try to slip a thin putty knife under the front edge of the console to release the clips holding the console on.
Dec 09, 2010 | Kenmore 25862 Top Load Washer
Washing machine will not start at closing of lid
If it fills then does nothing your lid switch is malfunctioning. If it is just dead you will need to check to make sure the power is on, Make sure the water is on, try running different cycles.
Nov 03, 2010 | Kenmore 25862 Top Load Washer
Cold water wont work
Are you saying that the machine is not letting cold water into the machine? If so, the problem has to deal with the cold water inlet valve. Disconnect the cold water supply line at the machine, check to see if there is the screens are blocked with debri.
If it is ok, it's probally the water inlet valve which is the problem. It is an easy part to purchase at any appliance supply house or online. Hope this helps you.
Aug 24, 2010 | Kenmore 25862 Top Load Washer
The washer filled with water, But it stopped and would not go through any of the other cycles. No circut breakers triped, and power to a three pronged plug available. Sears Kenmore Washer 110. 25862400
try opening and closing the lid,you should hear a clicking sound just before the lid closes,if you don't you havea broken lid switch.let me know what you find
Jul 25, 2010 | Kenmore 25862 Top Load Washer
Kenmore 80 Series Model 110-25862 that won't start wash cycle
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
This is a very simple and inexpensive repair that you can do without the assistance of a repairman. The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement for your washer is 3949238.
NOTE: You DO NOT need to drain the washer to replace the lid switch. Once a defective switch is replaced, the washer will drain.
If you have questions, or need additional assistance, please post back and let me know. I hope this information is helpful.
Mar 19, 2010 | Kenmore 25862 Top Load Washer
KENMORE washer's motor humming
Remove belt 1st is the motor turning by hand....Its held by 2 or 4 bolts and motor plug for the electrics this has to be undone to remove...
Feb 17, 2010 | Kenmore 25862 Top Load Washer
Kenmore 25862 replacing lid switch
What is the model number? Normally, Sears brand washers begin with three digits then a period. As an example (110.25863).
Nov 12, 2008 | Kenmore 25862 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore washing maching 25862
yes you need to replace the motor coupling between the motor and transmission let me know how you make out
Dec 21, 2006 | Kenmore 25862 Top Load Washer
Kenmore 25862 Top Load Washer Logo
137 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
