Question about Refrigerators
I have a groenland gas fridge CTL 350 and im looking for a parts list for this product. thank you Mark Lally
Im looking at buying an LG fridge with the double doors and freezer on the bottom. It also has the ice machine and water hook ups but it needs a gas refill how much will that cost?
I wouldn't buy any modern fridge that needs a gas refill. Needing a refill means that it has a leak. Modern fridges are 'sealed unit' compressors and should NEVER leak. If they do then there is a leak, often in the evaporator coils inside the fridge and commonly between the copper to aluminium joins. These leaks would need to be repaired however most piping is not easily accessible. Cost may be $100 to $300 for re-gas plus repair $$$ and unless the leak was located and repaired then you will be re-gassing again in days, weeks or months.
LEAK needs FIX LEAK and re-gas.
Oct 21, 2016 | LG Refrigerators
I NEED A USER MANUAL FOR ELECTROLUX GAS FRIDGE IN MOTOR HOME. MODEL IS RM 2260 AND PRODUCT NO. IS 9215430-01. GAS IGNITION SYSTEM NOT WORKING - THANKS FOR ANY HELP JAMES GREIG SMITH
Hello, here is the manual: -
http://web.me.com/danperkinsartwork/Autohomes-Bedouin/Manuals_files/Electrolux%20RM2260%20operating%20and%20instalation%20instructions.pdf
Also found this site with a list of parts for the fridge you mentioned
http://www.leisureshopdirect.com/Caravan/ventilation/Dometic_Caravan_Fridge_Spares/Dometic_RM2260_Fridge_Spare_Parts.aspx
Hope this helps, good luck
Aug 04, 2011 | Electrolux Refrigerators
LG electrocool fridge - serial no. 407KRXD00074; the frost free freezer has a huge ice build up, please assist. im also trying to find the manual book for the fridge.
Please check the link :
http://www.lg.com/us/support/product/support-product.jsp
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Refrigerators
The fridge part of the unit has stopped working i.e. cooling. The freezer seems ok. There is no coolnest or condensation od the back or side walls of the fridge unit
Hello
The fridge has lost gas or its dryer is blocked< you will need to have it looked at by fridge specialist
Thanks
Jun 08, 2011 | Refrigerators
Fridge not cooling
your gas level is low. look for gasleak and charge with gas.
Aug 05, 2009 | Dometic RM2652 Refrigerator
Fridge not cooling freezer works fine?
hi im andy from ac refrigeration in south africa ur fridge is short of gas
Jul 29, 2009 | Refrigerators
Mark I Series fridge not freezing
Please list the complete model number found inside the refrigerator on on the door frame. With the model number I will be able to help you better. If your refrigerator is an older model then with what you described could possibly be a defrost timer gone bad. Let me know what you find, Thanks,Sea Breeze
Mar 23, 2009 | Refrigerators
My subzero fridge is not cooling like it should. milk will sour in about 2 days. Im trying to find a list of dealers in the Brewton, Alabama area. Im having a hard time finding someone to do a service...
Your issue is;
"my subzero fridge is not cooling like it should. milk will sour in about 2 days. Im trying to find a list of dealers in the Brewton, Alabama area. Im having a hard time finding someone to do a service call, thanks, Daniel"
Before contacting a servicer, you may want to check on a few simple things first.
1. Are all doors closed and sealed tightly all the way around?
2. Are the cold controls properly set or adjusted high enough?
3. Is the condensor coil clean?
4.Frost build up in freezer on the back wall. This issue would be a defrost cycle problem and may require a technician.
This link should allow you to connect with a local service agency
http://www.magicyellow.com/category/Appliances_Household_Major_Repair/Montgomery_AL.html
This link may also be of some help.
http://www.constructiondeal.com/service/Appliance-Repair.552.html?rid=5&aid=552
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 24, 2008 | Refrigerators
Refrigerators Logo
307 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
