Question about Rowenta DG-980 Iron
Drain screw I am unable to unscrew the drain screw with either a quarter or a wide screw driver. I had the unit repaired at an authorized repair center in Northern California and have been unable to remove it since it has been returned.
    Scholar:
  • 70 Answers
He, if the repair was done within their warranty period, try calling their service department. It should be covered...beyond that, I would say that someone either overtightened or cross threaded the drain screw. You might warm up (but not fully presurize) and see if you can loosen it 1/4 turn counter clockwise (no further) and let it cool before removing.
Posted on Aug 09, 2008
The electrical connection 0n Rowenta steam iron DG5030 is inconsistent. I wish to disassemble and check the tightness of connection
Screws may hold the shell together but the halves are usually clipped together by hooks around the edge of the shell to discourage would be 'electricians' from doing home repairs. Once you've removed the screws and the body held by the screws doesn't come apart, look for a point where you can insert a screw driver in it to pry the body part out. If you can't do that, then don't do it. best thing to do is take it to a repair agent. At least it's safer.
Dec 28, 2014 | Rowenta Irons
Repair simac 7520 steam generator iron
Try to make a gru using a haksaw blade and use - scerwdriver.
Apr 03, 2014 | Irons
My Rowenta DZ9080 has a flashing yellow light but no heat, can you help!
when I contacted rowneta about this they ask us to contact the repaire shop IN small appliance in NY I did mail them unit after stating the problem they have send me mail that They are unable to repaire the unit because of unavailability of parts and now they want additional amount to send me back the unit. Its just redicules to spedn 35% of cost to received unrepaire they could have told me before hand by model number and type of problem that they are unable to repaire This is really cheating on part of rowenta and repaire shops SO be carefull before you send it for repaire
Aug 20, 2011 | Rowenta DZ9080 Iron with Auto Shut-off
I have a Rowenta DG-980 steam generator. It spits little grains of something when I use my iron. It doesn't hurt my clothing, but I have to brush the stuff off my clothes when I am finished ironing them. I...
Hi, Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
May 06, 2008 | Rowenta DG-980 Iron
Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Feb 25, 2008 | Euro-Pro Steam Generator EP8001 Iron
Repair of Steam Iron
I just removed the two screws on the bottom of the cord winder and made the screws tight again, works like a charm.
Feb 17, 2008 | Irons
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
Rowenta Iron
These are called tamper proof screws and you have to get them from the manufacturer. You have to be an authorized service center to get them. There were too many law suits aganinst the companies so they placed these special screws on the units so the do-it-yourselfers can not open them. I think they just do not want the units repaired and this is their excuse. They would rather have you toss the unit and buy another one. Sorry I can not be of more help.
Oct 24, 2007 | Micro Pro 7599 Iron
Rowenta DG-980 Iron Logo
94 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
