Cant find filter location rheem rhqa-1620t
3 Suggested Answers
  • 30 Answers
SOURCE: Getting new system How many Tons would a Rheem Air
The Rheem model RHQA-0805B is a 6-ton unit.
Posted on Aug 02, 2009
  • 1033 Answers
SOURCE: I have a RHEEM RHQA 1010B a/c unit that is pouring
Hello, usually water will leak from a furnace if the condensate line is clogged, or the condensate pan is cracked. If you have a shop vac try to hook it up to the outlet of the drain line and use the suction pressure to remove the sludge that is clogging it up. If the drain line appears to be clean the most likey the condensate pan is cracked or rusted and causing the leak.
Posted on Jul 13, 2011
Rheem Criteria II furnace filter location
If it's an updraft, filter may be at bottom of unit. Filters are usually installed in the return air side of the system. If you have a return air plenum it may be under a removable plate cover. Also check you return air grill inside your house, filter may be inside this grill,which have opening latches.
Mar 19, 2016 | Filter Heating & Cooling
I have a Rheem rhqa 1010 b and need air filter size.
Just measure the filter housing (LxW) and buy it at walmart, lowes, hom depot etc.
Oct 07, 2013 | Heating & Cooling
I have a Rheem Heat and air unit. Model # RGAC-080AW Serial # CM3D104 F4782 4794 and need to find out where the filter for the unit is located.
What filter are you talking about?
Air filter: Usually with a heat and air unit, the air filter is located behind the return air grill.
Return air grill looks similar to ordinary ceiling or floor grill where the hot or cold air blows into each room. Except the return air grill is larger and is usually put close to the heat-air unit.
Remove the grill and replace filter every 3-6 months.
If no filter is present, then dust and hair get stuck on the coils and unit will not meet temperature setting.
See image of typical air filter:
http://www.instablogsimages.com/images/2009/02/12/air-filter_IYR3W_69.jpg
Jul 30, 2011 | Rheem Water Heaters
I have a RHEEM RHQA 1010B a/c unit that is pouring water out of the bottom....please help find cause and solution. PS it is very humid where I live!!!
Jul 13, 2011 | Heating & Cooling
I cant find a reset button
Reset button is on the top thermostat which is located behind the top access panel taht is removal. It will have a screw in it to remove and behind the insulation will be the thermostat..
Jul 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
May 23, 2010 | Heating & Cooling
How old is a rheem rhqa-122oj air handler and what is the max wattage.
ampsxvoltage=watts so if you know the amp draw should be on machine and voltage just multiply as far as age undetermined
Feb 02, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Sep 30, 2009 | Water Heaters
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
