Question about Panasonic Televison & Video
I have a Panasonic TX-76PW10A which is stuck on S-Zoom (cutting off people's heads.) The remote does not have 'ASPECT' control on it. Strangely, my remote (N20AJB000080) looks slightly different to that in the manual; without the buttons on the left. Is there any other way to reset the TV or change the ASPECT ratio? (I'm trying to avoid getting a universal remote.) Thanks, Ron.
elecgooroo
  • 57 Answers
SOURCE: heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Posted on Dec 10, 2007
SOURCE: LG 32'' LCD TV aspect ratio self switching
Not a real solution actually. The store where I purchased the TV changed mine with another one...
Regards,
Massimo Moruzzi
Posted on Nov 30, 2008
  • 1039 Answers
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Posted on Apr 25, 2009
  • 3 Answers
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Posted on May 17, 2009
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
How do I stop the words from being cutoff on the tv screen?
You need to check the zoom or aspect ratio on your TV remote and or your cable/satellite remote. The zoom or 16:1 aspect ratio often cuts off words if the movie or show is in 4:3 ratio.
Jan 04, 2015 | Panasonic Viera TC-P50S1
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Picture on screen is too big head of people are cut off it does not show complete picture
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Jul 12, 2011 | RCA HD52W59 HDTV Projection Television
Panasonic TV model no TX-32PD30. Resolution has changed ie become larger and we are losing full screen picture - people are cut out of the screen.
The most likely cause of this is that you have accidentally changed the screen aspect ratio. There should be a button on the Panasonic remote marked "ASPECT". With the TV switched on, try pressing the "ASPECT" button repeatedly until the picture either returns to the correct size or you are unsuccessful and cycle back to the original picture size.
You will probably find that you are currently on one of the "ZOOM" settings. The correct setting should either be "AUTO" or "16:9".
If this does not solve your problem, please post back for further assistance. If you are using another receiving device, e.g. a Sky / FreeSat or Freeview box, it is also possible that you need to change the ratio setting of the receiving equipment. Please let me know the details of any additional receiving equipment you are using if/when replying.
Regards,
BElectric.
Dec 30, 2010 | Panasonic Televison & Video
I have panasonic television.fault its sound cuts out intermittently.model tx-76pw10a
resolder the cold solder around the audio and amplier section.....
Dec 26, 2010 | Televison & Video
My sony 32 tv screen cuts people's heads off. what can i do to correct it?
Look in ur remote control for a button like Zoom, Aspect,VIEWMODES,P.Sizes.Tries one of these buttons to tuggles the pictures sizes on the tv screen.
Dec 11, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
46 inch at least 3.5 yrs old
Has he tried both the aspect on the tv remote and for the cable/satelite box both? These both have their own aspect settings.
Josh
Feb 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
