Question about Amana Refrigerators
We have an Amana AFI2538AEW we have had two techs. out already and we have replaced the fill valve. But still we have no ice. What happened is it started leaking water out of the fill cup in the ice maker and through the ice despencer. It kept making ice but at a slow rate and that is when we turned the maker off. The first tech took the ice maker out and couldn't put it back in and the second put it back and said it was the fill valve and my husband and I replaced it ourselves. Unfortunatly its been 12 hours and no ice yet. What do I do I can't even pay for good help.
  • 126 Answers
There should be a float connected to this valve that tells the valve when to open and when to close it kinda works like the float valve in your toilet (check this float),as far as the water leaking out of the cup in the ice maker the float probably bad, Hope this works for u
Posted on Apr 03, 2011
Ice maker not putting out ice
The ice maker has a bi -metal thermostat which makes a contact when reaches minus 10 C and energizes the motor and the heater to remove the ice from the mould and dispense into the bin. So check the bi-metal thermostat.
Jan 14, 2014 | Amana / AFI2538AEW
Ice maker problem
Try empty tray and see if ice has froze on any area if not buddy hire a tech it may be electrical component of the ice make
Dec 11, 2013 | Amana / AFI2538AEW
NO ICE FROM ICE MAKER
You have a bad water valve or the fill tube where the water comes into the ice maker is frozen full of ice. Check the second problem first then if the fill tube is clear the valve needs to be replaced.
Apr 25, 2012 | Amana Refrigerators
My Amana bottom freezer refrigerator BB120TPW is 11 years old. The ice maker doen't make any ice. I can hear a noice coming from the unit, but no ice. I turned off the water and unpluged it. If it...
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
May 29, 2011 | Amana Refrigerators
My ice maker tube from supply fills up to the valve, but not to the ice maker. We replaced the valve to no avail.
Before repacing the ice maker (which operates that new valve) try to do a cleaning underneath to insure a good air flow for better ferormance and that may drop the temp sufficiently in the freezer for ice production to begin. Other than that the ice fill and harvest all originates from the ice maker.
Dec 18, 2010 | Amana Refrigerators
Amana model #tr25vl and serial # 9701127419, ice maker valve keeps getting stuck in open position which floods freezer . This has now happened 3 times in last 2 weeks .
Good day,
One of 2 causes. The valve sticks in the open position and won't close, or the ice maker electrical circuit tells it to keep filling.
99% of the time it is a defective water valve located on the back bottom of the machine. Changing it is basically a nuts and bolts job. Fairly easy.
If however the problem resurfaces you would need to replace the ice maker but since it is common practice to install a new valve when installing a new ice maker, it's really no loss.
Sep 15, 2010 | Amana Refrigerators
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Nov 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Oct 14, 2007 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
112 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
