Question about HP 4250 Monochrome LaserJet Printer
HP 4250 down (paper jam without paper)
Only work 1 day and now is with the papaer jam issue , there´s no paper on it and still what about the fuser or fusor where is located??
what he does it<<<'
  • 66 Answers
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Posted on Oct 29, 2008
SOURCE:
Hp 4250 laserjet is noisy and has numerous jams. page count is 137,619 maint kit has 39% left when searching event # 13.05.00 Fuser output paper late jam
Probebly the swing gear assy, this assy is driving the fuser, is defective. This is a common problem with these machines. Replacing the gear assy should solve your problem.
Feb 16, 2010 | HP LaserJet 4250n Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
WHERE'S THE FUSER ROLLER AND WHERE DO YOU PURCHASE FUSER OIL ON A HP LASER JET 4250 N PRINTER?
The 4250 uses an "assembly" that does not use fuser oil. The fuser is housed in the rear of the printer. It applies heat and pressure to the paper as it exits, melting the toner into the fibers of the paper. Some fusers are remanufactured. If done properly, with the proper amount of fuser sleeve grease, these fusers can last as long as the original equipment fuser.
If not properly trained, fusers should not be disassembled and rebuilt.
Oct 01, 2009 | HP LaserJet 4250n Printer
Plastic metal shavings inside printer
I had a similar problem on an hp-3052. I was getting pieces of plastic that were grey and yellow stuck to my pages and all inside the printer then papaer stared jamming. The problem was the fuser sleve which can be picked up on ebay fairly cheap. The bigger problem is installing the sleve over the fuser. I tried the repair my self and broke the fuser assembly. It's a cheap part but a pro should do the install this is definately not a diy fix.
Sep 26, 2009 | HP LaserJet 1020 Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP 4250 Monochrome LaserJet Printer Logo
189 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
