Question about Philips 37PFL7332D/37 37PF7332D/37 37 LCD 1366 x 768 HDTV 37 in. LCD TV
A couple months ago, my Philips TV 37PFL5332D/37 would not turn on. I tried everything - I unplugged and replugged the power cable, changed the batteries on the remote, tried manually turning on the power button, but only an orange light would show up on the power button. When the TV worked, the light on the power button was blue. A month or two later, I tried turning it on again, but this time the screen went to a software menu and it said I needed to update the TV. I went online, got the software update from the Philips website onto my USB, and I put my USB into the TV. It was said it was searching for any updates on the inserted device and this went on for 20 minutes, and then I decided to call up customer service. The first guy told me to unzip the file before I save it onto my USB and that if I had any more problems, I could call back again and they could walk me through it. It still didn't work, so I called again about 4 more times, each time a different person. But they all said they were not sure what to do to help me. The last person told me I could take it to service but I'm curious if there's a way I could solve this problem myself without having to take my TV to service. Thanks.
inst
  • 12 Answers
SOURCE: Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Posted on Aug 08, 2008
  • 90 Answers
SOURCE: Philips 42PFL5332D/37B no picture no sound but blue led light on
power supply board is going bad
Posted on Mar 03, 2009
MNfisherman
  • 11896 Answers
SOURCE: My Philips flat screen tv model 37PFL5332D/37 will
The only way to reset it is to leave it unplugged for 24 hours. If resetting it doesn't help let it turn on, you may have to replace the power supply
Posted on Jul 09, 2009
mbelectronic
  • 147 Answers
SOURCE: HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Posted on Jul 18, 2009
  • 92 Answers
SOURCE: Philips TV 37pfl5332D
Yes, it should do.
You may need to change the setting in the menu, but that's all. The same model was sold in the UK.
Posted on Sep 05, 2009
My TV was working and then all of the sudden the screen went blank and now there is a flashing red light that appears. I tried to turn everything off and back on (the universal solution to everything) but...
Hello
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
Jan 29, 2011 | Philips 37PFL5332D 37 in. LCD Television
Phillips 37PFL5332D/37 I have a blue power light but no picture, sound or anything. Please advise?
When tv power on.U have a solid LED green or red power light incadication?Yes,than 100% ur tv Tuner signal board is the problems and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 13, 2011 | Philips 37PFL5332D 37 in. LCD Television
My Philips 37PFL5332D 37 has a black screen when
ur problem is the inverter board , or bad capacitor on power supply
Apr 14, 2010 | Philips 37PFL5332D 37 in. LCD Television
The picture went out on my Philips 37pfl5332d TV
Have sound?Ur LCD inverter board is dead.Replaced this board to get picture back.It usally a long board.Tries Shopjimmy.com,Ebay.com for the replacement board part.
Feb 15, 2010 | Philips 37PFL5332D 37 in. LCD Television
Yes, it should do.
Sep 02, 2009 | Philips 37PFL5332D 37 in. LCD Television
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My Philips flat screen tv model 37PFL5332D/37 will not come on...what should I do to reset my tv
Jul 09, 2009 | Philips 32PF7320A 32 in. LCD Television
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Remote control stopped working
Hey. I paid the $20 for the expert advice and (I feel such a fool) I just had to unplug the tv and plug it in again for everything to work!
Martin000
May 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PFL7332D/37 37PF7332D/37 37 LCD 1366 x 768 HDTV 37 in. LCD TV Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
