Question about Watches
I recently purchased a Stauer notched watchband to replace my original Stauer Graves' 33. While I received the watchband (as a practice) Stauer does not send directions. It is a beautiful watch and I do not want to damage my watch. Please assist.
  • 2501 Answers
SOURCE: HOW IS A STAUER NOTCHED LEATHER WATCHBAND REMOVED
These sound like standard spring loaded pins.
To remove them I use a small screw driver and press it gently against one end of the pin, while pushing it lengthwise.
This compresses the spring and allows the pin to pop out.
(take care where you do this as it may fire out and get lost).
It may take several attempts to get pins out, as you have to experiment with the forces applied to get the right balance.
Putting the pins back in is also a skill. putting the pin into the strap, put one end into it receiving hole and press the other end as far as you can. Move the end in line with the other receiving hole and remove screw driver. It sounds easy but takes a little practice!
Posted on Jan 05, 2010
  • 2501 Answers
SOURCE: I want to send my atomic stauer watch for repair.
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Posted on Mar 20, 2010
escapement
  • 2334 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
cmcduncand
  • 714 Answers
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
SOURCE: purchase watchbands for the timex 1440 sport
My son's watch (WR 50M) broke... so I have a strap, if you'd like it.
He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh?
If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
Posted on May 20, 2010
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
How is a stauer notched leather watch band removed and replaced
No, he asked about a notched band, like on the Graves. Here the watch attaches not across the full 2cm or so but at two 6-7mm lengths around either side of a center protrusion, through which the pin slides.
Each pin consists of a longer part and a shorter end cap with a smaller pin maybe 2mm long that fits into the end of the longer hollow pin. These take a fairly serious pull to take apart, but must be pulled with care, for two reasons: one, so the pieces don't fly off and get lost when the pin comes apart, and two, so you don't accidentally torque the head sideways off the small pin, which is easy to do when you're pulling hard and not being careful. Vise-grips, with maybe thin wood like popsicle stick pieces to cushion the end caps might do, so you don't damage the end pieces as you squeeze, but again be careful. (If you do twist the endcap off its tiny pin, you might be able to glue it back with superglue (cyanoacrylate), but that's a patient precision operation by itself.)
Once the pieces are detached, the long pin will slide through the simple hole in the top and bottom protrusions from the watch case. You can customize your replacement band, set the pins, and gently compress them, again with widemouth pliers and a cushioning, they will go together more easily than they came apart.
Other Stauers use regular pins you can just pop off with the end of a pen knife, but this one is trickier.
Good luck :-)
Nov 09, 2010 | Watches
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
GOTO:
r/ David
May 12, 2010 | Fossil Watch
Mar 20, 2010 | Bulova Watch
How do I get the pins holding watchband off? I'm
With some practice you can get them out without damaging them.
With one finger press the pin upwards and use a small screw driver and gently press the pin toward the center.
Relax the finger pressure while pushing with the screwdriver and then return the pressure as you stop pushing with the screwdriver.
Some skill is required but you should be able to remove the pins after a few attempts.
Putting the pins back in by reversing the process (i.e. put one end in and press the pin gently onto the watch; push the spring loaded pin in while pressing it against the case and when the pin is far enough in, it will slide down the inner face into the hole.
Its easy! (after some practice!).
Mar 17, 2010 | Peugeot 307BR Wrist Watch
Jan 05, 2010 | Watches
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
Oct 21, 2009 | Bulova Watch
I recently purchased a stauer watch model E-244S on e-bay and did not receive any instruction manual, thought i was getting a quality watch, but really know nothing about the brand or its quality. It is a...
they cost about $60. they are cheaply made throw away dress watches. you didn't get ripped off. you just wasted your money on cheap chineese garbage, you are not alone.
wear the watch, throw it away when it stops or you don't like it anymore.
Apr 25, 2017 | Bulova Watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Watches Logo
498 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
