Question about Dishwashers
Our Technica bellisimo TBD4 S/S Dishwasher will not function. Lights are on and I'm sure there's a light for 'add salt'. Would low/no salt stop it from operating? And if so is it normal cooking salt or special salt crystals needed.
  • 641 Answers
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Posted on Aug 18, 2007
SOURCE: l63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
Posted on Jul 06, 2008
rickzilla
  • 706 Answers
SOURCE: I can't find the filter
If possible, can you provide the specific model of your dishwasher? ( That would help) also: see attached link to a site that shows pictures of generic GE dishwasher pumps.. at least one view shows a screen on the inlet of the pump however many dishwashers have a screen that traps food particles from draining into the pump and I would look at the loweset point inside the d/w itself for a drain opening. Some mfrs put a screen filter there..Could be more specific if you could provide model numbers though.. Hope this helps..
Posted on Aug 24, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: where to add the salt
I have just moved in to a property with a miele dishwasher model no. G1220SCU. I have not been able to locate a manual and it also requires salt to be added
Posted on Aug 14, 2009
I have a John Lewis dishwasher and all the lights are on red
all the lights will be on before you select a cycle, if the Rinse Aid and Salt warning indicator lights are on you need to add rinse and salt to the appropriate fill up locations
Dec 30, 2013 | John Lewis JLDWW1200 Dishwasher
Aquarius DWF32 and dealing with water softner
Good idea to check levels yourself, but wear rubber gloves as dishwasher salt will leave your hands very sore, simply remove cover from salt tank, using a wooden spoon handle or similar check salt level and refill if required, replace tank lid, never wait for warning lights, they may never come on, good luck.
Feb 18, 2013 | Hotpoint Aquarius Washing Machine Front...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Machine off completely
Hopefully a button is jammed in between positions - the lights are just indicating that you need to add salt to the reservoir and that your rinse aid is getting low.
Jan 09, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
L63 Salt light is flashing
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Powerpoint dishwasher TW26
cannot change the program low salt and low rince lights on but no lights on the cycle indicator lights.
May 02, 2008 | Dishwashers
Miele Dishwasher G856 SC cleaning assistance
Yes run a cycle with 2 cups of vinegar to flush it out
Mar 15, 2008 | Dishwashers
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Dishwashers Logo
Top Dishwashers Experts
