Question about HEWLETT-PACKARD HP G72-B62US Notebook
My laptop won't turn on. A few nights ago I put it to hibernate mode and it hasnt turned on since. I have disconnected the battery and power cord, held the power button and reconnected but still nothing at all except the power cord led on the side of laptop lights. What else can I do?
  • HEWLETT-PACKARD Master
  • 4,985 Answers
The PC is now 8 years old, here is and informed 8 year answer,
(age matters, in all things man made)
first off .,
1: run on AC line pack now, only, no main huge battery , until the PC runs again and then if does, get rid of the useless 8 year old battery (buy new one later)
2: no mention of the screen even once. ill guess it is dead.100%
not even text, that must work all the time.
3: DEAD screen 101,, put in a new coin cell now, HP name is RTC coin cell battery time for a new battery , coin, if it dies BIOS goes mad, even goes dead, even causing the BIOS text you saw for 8 long years "hit ESC to enter setup" (or f10) to go missing
if the text is missing, most times , the coin cell is dead.
the CCFL are not dead, it has LED back lamps, a good PC this is with that.
page 8 in your hp online service manuals states and I quote here.
Memory module compartment
Holds two memory modules, the wireless local area network
(WLAN) module, and the RTC battery
memory hatch open
ram pulled, behold RTC there. in view.
learn to use the GOAL of get BIOS working first.
if not tests go sideways.
BIOS must work or the PC is dead. (or RTC dead)
so learn to do that. power on and hammer the ESC key or F10 as it prompts you.... see the INFO page .
then run mem check there
then run hdd test there.
then see if time of day reads ok, date and year, if not RTC is dead.
do that first. on all PC made, and we can then do boots last.
HDD/and OS are last , in the chain of events.... always.
page 94 in your manual. quote 2.:
Open Setup Utility by turning on or restarting the computer. While the "Press the ESC key for
Startup Menu" message is displayed in the
lower-left corner of the screen, press
f10
Posted on Feb 20, 2018
    Director Badge:
    Uploaded 100 video answers.
  • 231 Answers
Call Laptop technical support Toll-free number 1-888-494-1155 (USA) AND FIND INSTANT SUPPORT by expert technicians and fix your problem in some times or same day.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 110 Answers
Try turning it on and press curl, alt, and delete, all at the same time. Hope this works.
3 Suggested Answers
SOURCE:
daniel528
  • 142 Answers
SOURCE: HP G62-225NR notebook will not
Try removing the battery and only using the power cord.
Posted on May 05, 2011
  • 156 Answers
SOURCE: Won't come out of hibernation
Power socket should be burned, another new, maybe you can help: http://www.2deals.net/Laptop-Power-Jack/Compaq.html
Posted on Oct 16, 2012
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
My asus will not turn on! only had it 1 day!
What version of Windows?
You can try disconnecting the power cord from the laptop, then pull the battery.
Let it sit with battery out for a minute. Put battery back in, plug AC charger in, and try to turn on.
If it's an older version of Windows, go to the Power control panel and make sure Hibernation is disabled. You can google "turn off hibernation on windows (your version)"
Best of luck! Jon : )
Jun 02, 2013 | Computers & Internet
Acer aspire one D255 will not charge
You don't have a real serious problem. Just use the Power Cord. Now if the Power Cord does not work, that's a real problem. If your power cord is good and you can use your laptop with it, then the problem is your battery is bad if it will not take a charge. It's time for you to buy a new battery.
Apr 09, 2012 | Acer Aspire One D255-2670
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
What does it mean if it's hibernating and won't turn on?
It means you need to remove the power cord, remove the battery,
put it back in, turn it on, and disable hibernation on your laptop.
May 11, 2011 | Samsung NP-NC10-WAS1US Notebook
Hi I closed my laptop to put into hibernation mode and then noticed 2 days later that the power light was stuck on and not in hibernation. Upon opening the screen back up nothing happened. No lights, no...
You can try this: Shut the computer down and unplug the power cord from the computer. Remove the battery, then push and hold the power button and sing happy birthday to it. Or wait 15 seconds. Then plug the power cord back and try turning the system on. After it boots up, providing this fixes the problem, you may then replace the battery.
Hope this helps!
Feb 16, 2011 | Dell Studio 1737 Laptop
Dell 1737 laptop won't turn on (A/C or battery powered). Last night I tried for 15-20 minutes then it worked. This morning it didn't work again (from stand by mode). I held the power button to shut down...
you have a BIOS bug when hibernation , leave without battery for few days try to turn on with the charger, and if turns on go to the battery settings and disable the hibernation option, later go to dell website and update your system BIOS.
please rate me
Aug 13, 2010 | Dell Studio 1737 Laptop
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
My toshiba laptop won't turn on!
Place the battery back in and the power cord. Follow the power cord all the way to the plug and verify nothing was unplugged by accident. (the box on the plug sometimes disconnects without the user knowing it) This could have caused your lack of power. Hope this helps.
May 09, 2009 | Computers & Internet
HEWLETT-PACKARD HP G72-B62US Notebook Logo
153 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
